Old 01-17-2012, 04:04 PM
RDCragg RDCragg is offline
2000 Windstar transmission slams into lower gear
I've been reading threads here about transmission issues on the Windstar and haven't come across what I'm experiencing with my van.
When slowing down for a turn or corner, and then accelerating, the transmission will hesitate and then slam into first or second gear which seems too low of a gear for the speed that I'm traveling. It doesn't do this when starting from a complete stop, only when slowing down then accelerating.
From reading posts here I know there are various sensors, solenoids, etc. that can be at fault. Of course I'm hoping that it isn't the transmission itself.
Any help or direction is appreciated.
Old 01-17-2012, 05:01 PM
12Ounce 12Ounce is offline
Re: 2000 Windstar transmission slams into lower gear
The actual shifting is done by "servos" ... which are hydraulic piston gizmos that take a small hydro signal and amplify it into a larger mechanical force. These servos have lots of 0-rings that can fail .... I had one failed due to a broken cir-clip. May not be the problem ... but a cheap fix if it is.
Both servos are on the backside of the tranny ... one is easy to get to .... one not so easly .... things have to be moved and the tranny rear lowered a bit. Not rocket science ... but there are some pre-loaded springs/screws that can be trouble. A little reading in a shop manual is a good start.
Old 01-21-2012, 10:24 AM
Windstartled Windstartled is offline
There are fairly good chances it may be a sensor issue even though a transmission shop would likely tell you your tranny is dying. Based on their definition of a doomed transmission mine has been "dying" for 7 years and yet is still in pretty decent shape, imagine that. Twice I had major odd shifting issues and twice was told transmission was going but, miraculously, replacing the VSS fixed the problem at once. I suggest you fetch the codes and see if you have VSS or TRS errors before having any major transmission work done.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Old 01-21-2012, 04:01 PM
Thanks for the replies.
Does the VSS = Vehicle Speed Sensor which is mounted on the top of the transmission?
Does the TRS = Transmission/Transaxle Range Sensor, otherwise known as the Neutral Safety Switch? If so, where is it located?
Old 01-23-2012, 01:00 AM
Indeed it is. VSS issues are a major source of funky shifting behavior. I had a problem with my van that caused the VSS to report only half the actual speed of the vehicle, At first I thought it only affected the speedometer but didn't take long to notice that shifting was messed up as well. If you're doing 20mph but the tranny "thinks" you're moving at 10mph it may downshift unexpectedly and you will definitely feel the slam. This also dramatically decreases fuel efficiency in city driving.
No, I wasn't paying attention when I typed TRS, I meant to say OSS which is what some people refer to the VSS as because it is called that on certain vehicles. Sorry about that.
Transmission Slamming Into Gear SnipesXxX Grand AM 4 10-31-2008 11:52 AM
98 Jetta Transmission slams into 1st lumpylou '97 - '03 0 04-06-2006 02:59 AM
transmission slams into gear mp32223 '97 - '03 11 04-12-2005 03:43 PM
2001 i30t transmission slams into 2nd gear mookster1 Introductions 0 08-04-2004 06:07 PM
03-Transmission Slams into Gear! que22 '97 - '03 11 05-25-2004 10:30 AM
