Vent control problem - 2004 Echo
Hello: I am having a problem with the vent control knob on my 2004 Toyota Echo (4-dr sedan). The knob switches through the main settings but cannot seem to switch to the two outer-most settings (that is, the face-only setting and defrost-only setting; see photo). If I try switching to these settings, the knob simply springs back to the closest mid-point setting. I have also noticed that if I turn the knob to the left-most setting and then try turning back to the right-most setting, the knob will spring-back to the midpoint between between feet-only and mixed feet and defrost setting. Can someone please help me troubleshoot this and provide a possible solution. Thanks!
Re: Vent control problem - 2004 Echo
It sounds like there is something obstructing the doors. Does your car by chance have an cabin air filter? While extreme, I've seen a duct become totally clogged with debris because the filter was never changed (the owner didn't know it was there) and kept the recirc door from moving such that the gear broke. Or if it is missing, foreign objects (and critters) can make their way in there.
Sometimes you can see the cable that runs down from the back of the dash to the actuators for the doors. You can trace it to see if it has come loose or somethings gotten in the way. You can also usually see the ends of the doors poking through the main duct trunk and watch them rotate as they move. A shot or two of lube could help. Short of tearing apart the dash, this is your best shot.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
| Tags |
| control , direction , knob , vent |
