Tires
Hello all. I have another question about a car other than a Grand Prix. I know this is the Grand Prix forum, but all the other forums seem to be pretty dead. Anyway, I was wondering if anyone knew if a P215/75/R16 tire would fit on a '99 Olds Intrigue. I believe the factory size is P215/60/R16. Thanks in advance.
-Greg |
Re: Tires
Yes they will fit.
Re: Tires
Incorrect. They wont even come close to fitting.
215/60/16 are 26.16" tall 215/75/16 are 28.70" tall
| The Following User Says Thank You to Stealthee For This Useful Post: | ||
GregGP (01-17-2012)
Re: Tires
GregGP, if I've mis-infomed you, I apologize, but i'd swear I've seen them mounted on a Intrigue before. Maybe not!
Re: Tires
They may rub on the strut or fenderwell. like stealth said they probably will not fit.
2004 GRAND PRIX GTP COMP G. VIN 4 : OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST. 2004 Honda Odyssey EX-L
| The Following User Says Thank You to rickisrad For This Useful Post: | ||
GregGP (01-17-2012)
Re: Tires
I didn't think they would. Thanks guys!
Re: Tires
215 = width of tire in millimeters 60 = height of tire from tread to bead, as a percentage of the width. In this case 60%, or 215 x .6 = 129 mm = 5.08 inches 16 = diameter of wheel, in inches Total height = 5.08 + 16 + 5.08 = 26.16"
