Go Back   Automotive Forums Car Chat > Lincoln > General Discussion
Old 01-14-2012, 04:40 PM
clauritzen clauritzen is offline
1979 Lincoln Mark V Fuel Pump Location
My dad has a 79 Lincoln Mark V that he is trying to get running again. He says it does not appear to be pumping fuel. Can anyone tell me where the fuel pump is located?
thanks
Old 01-14-2012, 04:47 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 1979 Lincoln Mark V Fuel Pump Location
It's a mechanical pump bolted to the side of the engine near the front. I think its on the driver's side, but can't quite remember. Just follow the fuel line from the carburetor down the front of the engine. It leads directly to the pump.
FWIW if the car's been sitting a long time, you might have another problem interrupting fuel flow:
possibly a rusted-out fuel line
a blocked fuel tank pick-up.
Also the fuel filter (which is screwed into the aide of the carb) may be blocked.
Finally, the carb float and/or needle-and-seat may be stuck in the "up" or closed position.
91 escort cant locate fuel pump relay or fuel pump fuse thesandmanisme Escort 2 10-21-2008 02:38 AM
1979 Lincoln Mark V cool74 General Discussion 0 07-22-2008 07:13 PM
Help. 94 Lincoln towncar fuel pump problem AtruEulogy Town Car 10 04-26-2008 09:46 AM
93 lincoln changing fuel pump retcoa Town Car 1 02-16-2007 05:26 PM
fuel pump location? Tominos Engineering/ Technical 0 08-04-2002 01:06 AM
