Old 01-13-2012, 10:46 PM
DrUnKeN_TiGeR DrUnKeN_TiGeR is offline
2000 cavalier z24 fuel pump issues
So my mechanic replaced the fuel pump and the relay and the fuel filter due to one day it just wouldn't start and i couldn't hear the fuel pump..... it started briefly then died ... now it still wont start again... he has traced all the voltage and it is good however he gets to the fuel pump there is no voltage...
What would cause no voltage to the fuel pump?
Thanks in advance.
Old 01-14-2012, 04:35 AM
autojoe autojoe is offline
Re: 2000 cavalier z24 fuel pump issues
I would have towed to a different repair shop.the no start condition would have to be diagnosed.starting with the fuel pump circuit.......power and ground.if you are going to diagnose and have a multimeter then can proceed from there but testing would have to be done.
Old 01-14-2012, 08:53 AM
Tech II Tech II is offline
Spray carb cleaner into the intake and see if it runs as long as you spray...
2000 Jimmy Fuel Pump issue RI1470 Jimmy 2 03-03-2010 06:00 PM
2000 cavalier no fuel pump newsleet Cavalier 1 12-02-2007 06:07 PM
98 cavalier z24 water pump 2000VFR Cavalier 2 11-16-2006 06:06 PM
2000 cavalier Z24 ECU wiring diagram mugenrsx Cavalier 0 03-03-2003 05:33 AM
2000 Cavalier Z24 Coupe Question CurtHoward Cavalier 1 12-20-2002 09:31 AM
