Old 01-13-2012, 07:58 AM
R1ver R1der R1ver R1der is offline
Hot seat
On my way to work this morning as I was turning the seat warmer to lo from hi I was thinking it was warmer than usual.
Than I smelled smoke. I now have a nickle sized burn in the seat back.
Anyone ever replace a seat warmer?
R1ver R1der
2000 GL 120K and going strong
Old 01-13-2012, 08:16 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Hot seat
The seat will need to come out and the seat coushion cover(s) will need to come off.
Old 05-22-2012, 03:02 PM
i_hate_cars38's Avatar
i_hate_cars38 i_hate_cars38 is offline
Lost In The Darkness
Angry Re: Hot seat
read the net i did to late any year intruge is known for starting the seats on fire hazzard has all blinker controlls i found that out when my blinkers went out now i punch the dam hazzard area and they work for months inrigue was olds worst most problam prone line the problema are evrywhere i searched after i got it and hundreds aand hundreds of bad posts
Old 05-22-2012, 07:20 PM
Tech II Tech II is offline
Re: Hot seat
Natually, you will have to remove both seat covers(bottom and back)......if you have a burnt mark, you either live with it, cover it with something, color it, or replace it(expensive, unless you can find one in bone yard)......
Basically you just cut off the leads to the old heater grids, and the new grids come with harnesses, and you just peal off the covering and stick it in place on top of the old ones and connect the harnesses....then put the covering back on....
Of course, on some seats, getting those covers off is a challenge....
how hot is too hot? Mediaman67 Lumina 3 01-21-2006 06:34 PM
98 528i overheating and hot air goes hot and cold. jeffbeck 5 Series 5 12-14-2005 04:05 PM
Hot Seat/Dead Battery cdalmata Bravada 4 03-21-2005 07:29 AM
