Old 01-12-2012, 04:07 PM
wildhooker wildhooker is offline
timing issue 92 Cherokee
92 Jeep Cherokee 4wd, 4.0 motor, automatic. Several things have been done recently, new timing chain, coil, distributor and cap, map sensor, computer, cam shaft timing sensor. motor now will start and run. It runs well at idle, but the timing gets all out of whack as the RPM's increase. Is there a knock sensor on this motor, and could it cause this? If so, where is it located? Any other ideas?
Old 01-12-2012, 06:15 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: timing issue 92 Cherokee
Not sure about the knock sensor.
1st thing I'd re-check would be the timing chain installation. If it's off by 1 tooth / even slightly you'll have problems.
Also, check the vacuum hoses. There could be a vacuum advance on that engine but I'm not sure.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
97-Mirage, 1.5 L Timing issues IHMIRAGES Mirage 1 06-03-2011 11:42 AM
Spedometer issues rrood69 Cherokee 0 10-05-2010 01:05 AM
4x4 full time wont engage, grinds when shifting out of dawall032 Cherokee 2 09-21-2010 08:10 PM
1998 Jeep Cherokee Classic - Electric Window Issues Dre1989 Cherokee 1 06-17-2010 12:57 PM
1.8L AEB Timing Issues..Timing Belt Off??? sorry post is a little lengthy 98vwpassat '97+ 4 04-17-2006 04:13 PM
