Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-11-2012, 09:10 PM
chevyg2092 chevyg2092 is offline
Exclamation Dash lights
My dash lights wont stay on. I replaced the fuse and am still having problems. Advice?
Old 01-12-2012, 06:21 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Dash lights
Was the fuse blown?
The Original 97Bird
Old 01-12-2012, 08:34 PM
Re: Dash lights
yes the fuse was blown. replaced instrument panel a few days ago and only change was trip started to work. My odometer still does not work and dash lights come on and are dim then get brighter and then shut off. This is a real pain at night when u cant see how fast u are going.
Old 01-13-2012, 06:59 PM
97Bird's Avatar
Re: Dash lights
Did you have this problem before you changed the instrument panel? Is the panel you put in from the same year car?
The Original 97Bird
Old 01-15-2012, 05:22 PM
Re: Dash lights
Yes I had the problem before the instrument panel. Panel is from same year car. Maybe the dimmer switch is bad. I have no idea. The aggravating thing is that they work for a min and then it goes off.
Old 01-17-2012, 06:10 PM
97Bird's Avatar
Re: Dash lights
Do you have auto on/ delayed exit lamps and what year car is it? There are other lights connected to the same fuse. I'd disconnect the dash panel lights at the dash panel connector and see if the fuse still blows. A wiring diagram can be found by going to the second page of the Tech help thread and looking for my post about repair info (post #21).
The Original 97Bird
Old 01-19-2012, 07:04 PM
Re: Dash lights
I do have delayed exit lamps but i am not sure that is the problem. i have this dimmer thing i got off another car. i edited a pic to get it to look like the part. i am hoping this is not the problem. The pics are after and before. Respectively. The other switch on the right is a auto lamp.
Old 01-21-2012, 08:21 AM
97Bird's Avatar
Re: Dash lights
Did you try my advise about disconnecting the dash panel lights? What year is the car?
The Original 97Bird
Old 01-23-2012, 12:06 AM
Re: Dash lights
yes. its a 96
Old 01-23-2012, 11:01 AM
ricebike ricebike is offline
Re: Dash lights
this........
he's trying to isolate your problem
but my guess since the part you replaced already didn't fix it will be a wiring problem something in the circuit has rubbed off the plastic covering of a wire & is shorting out
Old 01-24-2012, 04:49 PM
97Bird's Avatar
Re: Dash lights
Originally Posted by chevyg2092 View Post
yes. its a 96
Well, what happened?! Did you look at the wiring diagram for your year car to see what else is on that circuit? Do the other lights in the circuit start off dim and then brighten like the dash lights? Disconnect each light or load, one at a time, until the fuse doesn't blow. When the fuse doesn't blow then you've found where to start looking for the problem.
Correct ricebike. You disconnect one piece of the circuit at a time to narrow down which part of the circuit, including wiring, has the problem.
The Original 97Bird
Old 01-26-2012, 08:32 PM
Re: Dash lights
i haven't had the time to find it but i am thinking of dropping it at a friends house who is a mechanic to see of he can figure it out. its too involved for me.
Old 01-28-2012, 03:48 PM
97Bird's Avatar
Re: Dash lights
Sorry to hear it's to involved for you. At least you tried! Let us know what the outcome is. Good luck.
The Original 97Bird
1997 Plymouth Voyager Parking / Running Lights - Dash Illumination Out levelbest Caravan | Voyager 3 09-25-2009 12:28 AM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
Dash lights,Tail lights soapy1 S-10 1 03-12-2009 09:00 PM
2000 Yukon, Cruise works - but no dash light. Tow/Haul no dash light - works? maxman Yukon 0 12-29-2007 08:44 PM
