Old 01-11-2012, 04:02 PM
slp4days slp4days is offline
93 blazer 4.3 vortex injector probs
Hi I have a 93 S10 blazer it has a 4.3 vortex engine in it I'm having probs with the injector and spider assembly I was wondering if anyone knows how to get the injector out and take spider assembly of and if anyone knows what numbers in the vin has to match so I can get injector and spider assembly from a blown engine thank you for your time
Old 01-12-2012, 06:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 93 blazer 4.3 vortex injector probs
What kind of a problem are you having?
MT
Old 01-12-2012, 09:45 AM
It won't start unless I spray starting fluid in it. I checked fuel pressor and it was fine and it didn't bleed off I had a extra ECM so I switched it out and it had no change I tested power at injector and it had power bout only thing I can think of doing now is change cpi thank you for any help you can give
Old 01-12-2012, 10:34 AM
corem corem is offline
Send a message via MSN to corem
Has the vehicle fouled out the back plugs. This is the most common thing that goes wrong with the CPI. Justany of them with interchange though. Also make sure the distrubitor is giveing signaal to fire the injecter. Is theinjector getting power and ground. Just few good things to look at.
Old 01-12-2012, 10:48 AM
MT-2500's Avatar
AF - Advisor
What was fuel pressure reading?
12 volt power does not trigger injector
Make sure it has both 12 volt power plus injector pulse.
As said make sure and checvk that you are getting injector pulse.
Also I have found the wiring inside of intake to injector bad.
MT
Old 01-12-2012, 12:03 PM
If I remember right pressor was around 60 or 62 psi I haven't checked the pulse yet I haven't got a noid light to test with an I haven't found 1 around here I checked at autozone to see if they had 1 I could rent but they didn't ill look around again and see if I can find 1 that was 2 yrs ago that's when I first started trying to figure it out the reason I thought about just replacing the injector is iv read a couple post that pll was having the same prob as I am with the same engine but I think u guys are I right I should check everything before replacing injector thx for your guys help ill check pulse as soon as I can get my hands on a noid light
Old 01-12-2012, 12:06 PM
Ill check the back plugs too thx again guys
Old 01-14-2012, 03:02 PM
I just plugged noid lite into injector plug it flashed when I cranked it over but when the key was in the one position I dunno if its suppose to in the on position
Thx for any help anyone can give me on this
Old 01-14-2012, 03:42 PM
MT-2500's Avatar
AF - Advisor
It should pulse only when cranking.
Does it still have spark to all plugs and proper fuel pressure when cranking?
Where are you checking injector pulse?
Will it fire with a shot of carb cleaner?
MT
Old 01-14-2012, 03:51 PM
Ya it starts with starting fluid an ran good till starting fluid burned up I took the plug off the injector and pluged noid lite in there to test in
Old 01-16-2012, 06:22 AM
MT-2500's Avatar
AF - Advisor
If you have injector pulse and proper fuel presure and it fires with carb cleaner but not witout carb cleaner you have a fuel delivery problem.
Check the injector.
MT
Old 01-16-2012, 10:10 AM
Do you the best way to test the injector without replacing it like take it out of motor and crank it over and see if any fuel comes out I don't no if injector needs to be grounded to the engine to work thx for your help
Old 01-16-2012, 10:15 AM
MT-2500's Avatar
AF - Advisor
Do you have the upper intake removed?
MT
Old 01-16-2012, 10:22 AM
No I just have the plenum off
Old 01-16-2012, 02:49 PM
MT-2500's Avatar
AF - Advisor
Make sure the plugin is good at injector and still getting injector pluse there and fuel pressure.
Then pull injector poppet and see if it is squrting fuel.
If not your injector is dead.
MT
'93 S-10 Chevy Blazer 4x4 4.3 - Fuel Injector Related Problems??? dknape Blazer 19 01-06-2009 01:51 PM
95 Blazer 4.3 Vortex harley2457 Problem Diagnosis 3 01-04-2009 10:57 AM
94 s10 blazer 4.3 vortech starting prob. please help! ky686 Problem Diagnosis 8 04-03-2008 09:14 AM
93 gmc jimmy 4.3 vortex fuel problem logden5751 Jimmy 3 01-16-2005 02:40 PM
1998 chevy c/k 1500 silverado 4.3 vortex dety64 C/K 0 09-13-2004 09:45 PM
