Old 01-10-2012, 02:14 PM
DC1263's Avatar
DC1263 DC1263 is offline
Headlight Restoration:UV Clearcoat or Not ?
Gentlemen,
This past Sunday I needed a project so... I went out and got one of them there 3m Headlight Restoration Kits. Headlights were not yellow but heavily sandblasted from 198,000 miles of almost entirely highway driving, Figured I'd give it a try. Well the results were amazing, both lenses look like new, however after some additional reading about applying a UV "sealer" I found that the lenses actually had a UV "coating" on them ... and I had just removed it,,,
So Periodic buffing and sealing vs UV clearcoating ?
My guess is the lenses will now suffer from even greater sandblasting now that the clearcoat layer has been removed,,,
I dont mind the periodic maintenance of buffing and waxing to keep them clear but I am major concerned with protecting the lenses from the sandblasting effect
I have information overload from reading the web about this issue , way too much information...
Anyone done a UV Clearcoat, Acrylic Enamel Method ?
There is another method out there using Minwax Spars Urethane and mineral Spirits 50/50
Some say Good,,, Some say Hell No...
What Say You ???
Rapidly Approaching 200,000 miles,,, All Is Well,,, Knock, Knock, Knock on Wood !
"The First Step For Successful Troubleshooting Is Eliminating The User As The Source Of The Problem"
2006_Grand Prix_Liquid Silver Metallic_
Black Leather_3.8_198,500
Old 01-10-2012, 06:15 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Headlight Restoration:UV Clearcoat or Not ?
Nice!
Sorry that I have nothing to say about the clear coat but I've been trying to find any reviews about that 3M restoration kit; now that you mention it worked great for you I can't wait to try it on my cars.
I wonder if you would mind posting some pics, please.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-11-2012, 12:59 AM
trannyman52 trannyman52 is offline
have used power buffing compound with a buffer with good results though needs to be re-done about once a year....
Old 01-11-2012, 05:24 AM
DC1263's Avatar
First two pix are before, Obvious pitting and frosting from being sandblasted for so many miles
Next two are after sanding with 500, then 800 grit paper supplied it the 3M kit
The kit comes with a Trizact pad foam rubber pad embedded with 3000 grit,,, use wet
Then finish with the foam polishing pad and little packet of rubbing compound also supplied in the kit
Pix are before, after sanding, after polish, I don't have a before of the drivers side but same as passenger
Don't rush it and pay attention to the details, kept me busy for about 3 hrs from start to all cleaned up
Awesome totally awesome!!
The Following User Says Thank You to DC1263 For This Useful Post:
olopezm (01-12-2012)
Old 01-11-2012, 05:09 PM
olopezm's Avatar
Wow! Those are great results!. Thank you for posting the pics.
Just a final question, is the product enough for just one pair of headlights?
Oscar.
Old 01-11-2012, 06:01 PM
aleekat aleekat is online now
I did a mazda 626 a month ago. I have enough left over to do another set of headlights.
The sealer: RainX makes a spray bottle of headlight sealer that claims to protect UV. I got it like at an autozone, advanced auto. etc
The Following User Says Thank You to aleekat For This Useful Post:
Old 01-11-2012, 06:12 PM
DC1263's Avatar
RE : Just a final question, is the product enough for just one pair of headlights?
The mandrel that comes in the kit definitely has more life left in it
and you could probably get more use of the trizact pad and the foam polishing pad
but you only get 6/500 grits and 4/800's in the kit and I used the hell out of those so you would have to get more of them to do more lights, they are 3" round 3M Hookit discs and are available everywhere
Old 01-12-2012, 11:35 AM
olopezm's Avatar
Nice!
I like that even more! Thanks for your answer.
Oscar.
Old 01-15-2012, 07:47 PM
doctorhrdware doctorhrdware is offline
There are film covers for the headlight, these are similar to the cell phone touch screen protectors. I have them on the wife's Silverado truck. I just replace the film when needed. It is better then having to replace headlight housing assembly. I have to replace the headlight assembly on the GP. They are too far gone to be able to polish out the dullness. Driving at night the headlights are so dim.
Old 05-04-2012, 06:52 PM
bmm341991 bmm341991 is offline
try buyin a can or clearcoat and doing that it worked on mine
Old 05-05-2012, 03:17 AM
There is like a lexan film that you can buy to protect the head light. The ones on my GP are too far gone to repair them. Mine are 10x worse then what yours were. I don't want to waste money on using the 3M headlight restore kit. Just to end up having to replace the head light assemblies anyways.
1990 Le Baron Headlight covers do not work? shamrocksheik Lebaron 1 06-25-2009 11:06 PM
Headlights Dim/DRL Not Working lance_kidd Grand Prix 6 05-19-2009 06:10 AM
2001 Silverado - headlights dim when not accelerating? Faze3 Silverado 17 10-08-2004 08:17 AM
Headlight tip, but not what you think Hiroboy Car Modeling 6 12-29-2002 07:30 AM
