Old 01-09-2012, 03:56 PM
AnatomyHorror AnatomyHorror is offline
98 Sunfire 2.2 won't start/has power/won't turn
Hi, first let me explain what happened when the car stopped completely.
I drove it out the other day and the battery light was on (nothing new it's always on). But also the ABS light was on. So I went and put some gas in it, and now both those lights and the E-Brake light was on (even though it was not up).
I stopped at the movie store and hung out for a bit (family owned). When I went to get in my car, the car wouldn't start but it did produce several clicking sounds.
So I jumped it and drove it back towards home. As I was driving home, the Battery Light, ABS light, and Air Bag light were all on. Right before I pulled into the driveway, the car produced a few chimes (as if I had left my headlights on with no key in the ignition).
I parked the car, turned it off, then tried to turn it back on and absolutely nothing. No clicks, but there was power, as all of the dashboard lights were on.
My battery was bought in April 2011. My alternator is old though. I'm not very good with cars, so my grandpa had been working on it. We took the alternator off and went to a local car repair shop. The guy told my grandpa it may be the 'computer'? He said to hook a fully charged battery up to the car and see if it'll start.
I guess that would rule out the battery if it worked or not, but what's this deal about the computer? ECU or something?
Any information is appreciative . Thanks for reading sorry for it being so long.
Old 01-09-2012, 08:13 PM
Tech II Tech II is offline
Re: 98 Sunfire 2.2 won't start/has power/won't turn
Do you know what the alternate name for those warning lights are called? They are called "idiot" lights......Do you know what the the red battery light means when it is on while the car is running? It means your car in not charging, and if you continue to drive the vehicle like this you will kill your battery(discharges it).....
Because your battery was discharged.....
He wants you to try and see if the car will start and run with a fully charged battery......but it starts when it is jumped, so we know the problem is a charging problem(if your battery is ok)....however, even though your battery is fairly new, running the vehicle with the battery light on, could have weakened the battery....should have your battery charged, and then checked out.......
I don't have a schematic for this system, but the output of the alternator is controlled by the voltage regulator( some are external, some are built into the alternator, and in some cases, the car's computer controls the alternator output).....
Do you have a voltmeter? Charge the battery, and start her up...fully charged battery should read 12.6 volts(engine not running).......with the vehicle running, the battery should be reading greater than 13.0 volts, if the alternator is charging......many alternators have been replaced erroneously, due to a blown fuseable link.....inputs to the alternator have to be checked before condemning the alternator..
Old 01-09-2012, 09:04 PM
Thanks for the reply.
I forgot to mention that while not on, we did check the voltage of the battery and I believe it was 11.4 or 11.6. We'll fully charge it tomorrow and see what happens.
I'll have to get in to the manual and check out the lights problem. Usually when the battery light came on, I could turn the car off and then turn it back on, and the battery light would go away.
It's getting late for me to grab the manual and see as I'm about to go to bed and have to get a tooth pulled tomorrow hah. But I will relay this information and respond tomorrow afternoon.
thanks again.
Old 01-10-2012, 11:50 AM
I think it's definitely the battery. Hooked up my grandpa's tractor battery to the car and it started up no problem, no 'idiot lights' on or anything. Gonna take this old battery back and see what they'll do.
Old 01-10-2012, 01:35 PM
aleekat aleekat is online now
I didn't see where you put a voltmeter on the battery with car running.
Old 01-10-2012, 01:50 PM
While running, hooked up to my grandpa's tractor battery it was reading over 14 volts.
Old 01-10-2012, 09:02 PM
With less than a year on your battery, you should get a free exchange. Word of caution, don't mention anything about charging it or jumpering. Some places will void the exchange.
2006 Cobalt 2.2 ecotec engine replacement procedure needed dumb dummy Cobalt 3 06-26-2010 09:50 PM
1996 Olds 88 Starter grinds won't turn over car drparkwood Eighty Eight 1 07-24-2009 11:39 AM
'99 Sonoma 2.2 2wd Flooding? Ronniet Problem Diagnosis 3 12-30-2008 10:09 AM
2001 Intrigue; has power, won't crank or start rainadv Intrigue 6 06-03-2008 07:34 PM
Won't Start!! Replaced heater core and ran perfectly before but won't turn over now!! s10_blzer Blazer 3 08-15-2005 10:25 PM
