Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-09-2012, 10:58 AM
gmurrayjr gmurrayjr is offline
2001 gm ls fuel pump?
2001 gm ls would nt start . Noticed i couldnt hear fuel pump when turning the key . put in new fuel pump relay and i could hear pump and it started. 3 starts later it wouldnt start . Fuel pump not working with turn of key . Changed relay again and still wont work . Is it my pump finally done?
Old 01-09-2012, 01:55 PM
Re: 2001 gm ls fuel pump?
This vehical has 50,000 miles on it.
Old 01-09-2012, 06:13 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
First check all fuses. Then check the inertia (fuel cut off) switch in the trunk. You can use a test light to see if the switch is sending current to the pump. If there is current coming out of the switch, it is a good bet the pump has failed.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-10-2012, 12:04 PM
I checked the fuel rail and no pressure. I checked voltage at the inertia (fuel cut off) switch in the trunk, it had 6v. Im confident now that the pump has failed. I will let you know after change out. Thanks for the help.
Old 01-10-2012, 06:54 PM
way2old's Avatar
TOKEN HILLBILLY
If there is just 6 volts at the inertia switch, there is a voltage problem. There should be 12 volts coming in and 12 volts going to the pump.
Old 01-10-2012, 08:25 PM
Ok , so now im at a loss as to what to do next.
Old 01-11-2012, 07:32 PM
way2old's Avatar
TOKEN HILLBILLY
Check where the current comes from that feed the inertia switch. You may just have some corrosion on a connection somewhere. Does the switch have 6 volts on both sides or just the side to the pump? if it is the side to the pump, replace the inertia switch.
The Following User Says Thank You to way2old For This Useful Post:
gmurrayjr (01-18-2012)
Old 01-18-2012, 08:46 PM
Turned out to be the fuel pump . Thanks for the help.
Old 01-19-2012, 05:16 PM
way2old's Avatar
TOKEN HILLBILLY
Thanks for the fix reply. We really appreciate that you took the time to respond with the fix.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
