Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 01-07-2012, 02:51 PM
Bigsand1985 Bigsand1985 is offline
96 Tahoe help!!!
Hello everyone, this is my first post!
I have a Chevy Tahoe 1996 vortec 5.7 high miles! I have replaced the fuel pump, fuel filter, Maf sensor, air filter(k&n), spark plugs and wires, cam shaft position sensor, rotor and cap, spider assembly. All within a few days. I just finished with the spider assembly and now it runs like crap. Misfires like hell, random misfire code shown with a blinking CEL. I have read a lot of other pages and hope someone can help me. I've dropped a significant amount of money already and hope I don't have to spend much more. Help!!!
Old 01-21-2012, 08:18 PM
jamesslcx jamesslcx is offline
Re: 96 Tahoe help!!!
Bigsand1985, how many miles is high miles? At what temp does it misfire? Have you figured out anything yet?
Old 01-21-2012, 08:52 PM
Not sure if it's a misfire or not. Got it running, coil was bad. Still feels like it sputters. Happens at all temps and mostly at low speeds. Misfires at times when I let off the gas.
Old 01-21-2012, 09:03 PM
FishFind FishFind is offline
One Hot Shot
check for play in your distributor, Wiggle it left to right. should move less then 1/8 inch.
Mine had the same issue and it ended up being the gears on the bottom of the distributor have worn and when I put the new cap on it was not lining up at the correct time.
If yo do have play you can test if it is the gears by taking the screws that hold the distributor off and twisting the whole distributor cap clockwise while running.
Old 01-22-2012, 09:19 AM
I mend backfires at times when I let Off the gas. And it's a 96 with 238,000 miles. Thanks.
Old 01-22-2012, 09:21 AM
Ok I'll check it. I just had the truck in the shop and the cap was replaced. I'll let you know what I find. Thanks!
Old 01-22-2012, 11:06 AM
Bigsand1985 have you checked for vacuum leaks? Checked compression?
Old 01-23-2012, 10:35 PM
joemffields joemffields is offline
you should also have test for exhaust gases leaking into the radiator
Old 01-23-2012, 10:49 PM
Good compression, vacuum system is good. Both were recently tested. I have not had the chance to test the gears on the dis. I can however move it either direction about an eight of an inch. Should it move at all of should it be completely stationary. Thanks guys for the help, as soon as I can get in there and test the gears I will let you know.
Old 01-24-2012, 03:29 PM
One Hot Shot
so you have 1/4 inch play. that is close to say. You can leave the screws out of the cap and twist the cap and wires a little counter clock wise. If you had missfire at idle then you should be able to tell if this is your problem by doing that. If it is your problem you will the engine smooth out when it is lined up correct.
Old 01-24-2012, 03:33 PM
Okay, ill take the screws off tomorrow and let you know what i find. Thanks for the descriptive fix!!!
Old 01-26-2012, 05:46 PM
j cAT j cAT is offline
you changed alot of ignition parts. so this was miss firing which is why you dii replace all this stuff????
you say the ignition coil was bad. if so the ICM can be damaged very easy especially if original.
Ignition Control Module ...................
Old 01-26-2012, 06:36 PM
777stickman 777stickman is offline
Service manual says no rotational play allowed when turning the rotor by hand.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 01-27-2012, 07:31 AM
The ICM is good, replaced, almost brand new. Coil seems to be fine, now I think the alternator is going out, making a wining noise. Check engine light came back on, solid, not flashing. I'm going to advance today to get the codes read. Will post again soon, thanks!
Old 01-27-2012, 07:45 AM
most auto zone's can test the ICM. they have a wells tester.
remove alternator belt check bearings. check voltage out should be a solid 14volt at normal operating temp. higher at cold start.
noise can be the power steering pump. if so replace this fluid.
05 tahoe torque converter out. . ??? help bcmagg Tahoe 8 03-22-2010 11:32 AM
Help Oil Cooler Lines oscales Tahoe 4 09-09-2009 08:44 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
wanna slam my 4wd 2dr tahoe. Help! FRISCOSCRAPER Tahoe 0 08-11-2005 09:04 PM
removing wiper arms 99 Tahoe...help please jgoose Tahoe 5 07-31-2005 11:52 PM
