I have isolated this problem to the driver door and what I think is a switch that moves when the door is shut.
Is this the part I need? http://www.rockauto.com/catalog/x,ca...,parttype,4360 Do I really have to take apart the whole door? How hard is this to do? I apologize if I've posted this somewhere before. I thought I did but I couldn't find it. Da!n thing ran my battery down tonight. SAVE ME WINDSTAR GOD!!! YOU KNOW WHO YOU ARE!!!!!
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org 1995 3.8L Ford Windstar GL -------------------------------------------------------------------------- "I drive the newest 1995 Ford Windstar anywhere..... when its not broken." Last edited by searcherrr; 01-07-2012 at 12:29 AM. Reason: PRAYING TO THE WINDSTAR GOD. |
Re: Interior and hood lighting blinking on and off as if controlled by Demons
I'm far from being the expert you need but here are my two cents.
I don't know if the '95 Windstar has the sensor integrated into the door latch (I know other '95 models like my Lincoln do) if so, you might want to try cleaning the LATCH with some WD40 to remove all dirt and stuff and then use some silicon spray to wash away the WD40 and lubricate the latch. This is a common problem with many Fords and that the solution that has worked for most of us. Oscar. EDIT: Just found out yours does not comes with the integrated latch and you're right about the part you might need. you can try cleaning it as I wrote above and see if it works. If it doesn't might want to try jumping both terminals in the harness and see if the problem goes away, just to be sure. I'm sorry I'm of no use when it comes to the replacement procedure, mine is totally different.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
This (the part I cited) would also cause the door ajar alarm to sound off continuously too right?
F'in aggravating and now I've pulled fuse 29 to save my battery so that means I can't roll down windows in addition to not having cabin lights. Well, I'll start simple with the oil trick. I just didn't think I should spray oil in there since somewhere there is an electric sensor that might catch the oil. I appreciate your reply olopezm.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org 1995 3.8L Ford Windstar GL -------------------------------------------------------------------------- "I drive the newest 1995 Ford Windstar anywhere..... when its not broken." |
You're welcome.
That's correct, it's a spring loaded contact that can get stuck with dirt. Cleaning it would definitely be the first step. Oscar.
I used to have all kinds of issues with interior lights either remaining on all the time or not lighting up when the doors were opened. I figured that because the doors would still beep when opened, the latch contacts were not the cause. When the lights got stuck on all the time the only way to temporarily fix this was to unplug/replug the battery, a major PITA for obvious reasons. Lived with it for two years until I replaced the battery cables with ones that had side post terminals, figuring these would be quicker to disconnect/reconnect to "fix" stuck on interior lights. Well lo and behold the cable change fixed all electrical issues instantly. Still scratching my head over that one because the old cables and connectors weren't loose or oxidized, could be that there was a problem with the battery posts that caused amperage issues I guess.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
Yes, it is probably controled by Demons. You see, Windstars were designed by Demons in the first place. The design philosophy was enchant "us", to spend our money and purchase one, then from that point, torment us forevermore.
Boycott Shampoo! KNOW YOUR RIGHTS! Demand REAL poo! |
