Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-06-2012, 11:40 PM
krazedpunk krazedpunk is offline
Someone plz Help ran out of options
I have 97 dodge dakota sport 5.2 that has been headache trying to figure out the problem.The engine has starting problems, it will only start mostly when the engine is cold but has a slightly weak crank.But when the engine is hot it will try to start but has a very weak crank like the starter is under big load.then once it finally does start u have to give it gas for a minute or so and slowly let off the gas pedal so the rpm dont drop to fast and the engine dies.Once you get past the rpm thingy the truck runs fine for as long as u want to drive it.Then when you shut it off, you usually have to play the waiting game until it cools down. but every now and then it will start up when hot but very weak and draggy.I have changed starter and new battery and even had them tested first, but still same problem and no codes what so ever.I also done fuel pressure test with 48 psi...Any help would be greatly appreciated Thx
checks good::Battery,,,,Alt,,,,fuel pressure,,,,,starter....no codes,,,,reads 10 volt while cranking using multimeter on battery and 12.8 when not cranking
Old 01-07-2012, 08:41 AM
phipps phipps is offline
Re: Someone plz Help ran out of options
Have you replaced the battery cables? Try checking your ground connections.
10 volts seems low to me. That would explain the slow cranking.
Old 01-07-2012, 02:36 PM
jamesslcx jamesslcx is offline
Phipps gave good advice about the cables, the idling problem is something else, probably a sensor, sometimes they can be marginal and not set a code. When was the last time you cleaned the throttle body or ran some injector cleaner through the system?
Old 01-07-2012, 02:44 PM
IAC motor controls idle speed, sometimes you can get by with cleaning it and the passage. Check you-tube for vid.
Old 01-07-2012, 03:46 PM
I was having issues with my 2000 Dakota dying at stop signs last winter. My throttle position sensor ended up being bad. I lucked out and it would at least set a code when it acted up.
Old 01-07-2012, 05:35 PM
Usually I recommend everyone check out a manual on the vehicle they own, it get's them familiar with the systems and workings of the automobile. Sometimes a person gets lucky and a code is set but not always, but if you read the manual you know which sensor and actuators could cause the situation you have.
Can Someone plz Help...? MadVs Cars in General 1 01-02-2005 05:42 PM
Someone PLZ help!! i need a sunroof for my civic! JDM_Sir Classifieds 4 10-22-2004 06:50 PM
I got a question, someone plz help. Fecomosis Camaro Discussions 2 05-02-2004 11:01 PM
Local gang but a bounty on me....someone plz help 90redgt Stress Release 151 01-19-2004 12:16 AM
Someone plz help fast To12o Celica 0 11-04-2003 12:11 PM
