Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 01-06-2012, 07:41 PM
78silverbird 78silverbird is offline
'00 Montana no fuel, pump is good...?
Can't start the wife's van. If I squirt gas in the intake, it'll fire briefly, then die. Put new fuel filter in, pump seems good, measured 58 psi at test port on fuel rail. Fuse for injectors looks good ... pcm?
Old 01-06-2012, 09:23 PM
Tech II Tech II is offline
Re: '00 Montana no fuel, pump is good...?
Are the injectors getting power? Are they getting pulsed?
The Following User Says Thank You to Tech II For This Useful Post:
78silverbird (01-07-2012)
Old 01-08-2012, 03:29 PM
Yep, that was it ... turns out, somehow while working on the wipers, I had severed two wires - still not quite sure how that happened, but after splicing, the van starts and runs as well as it ever did! Thanks for the input!!!
89 Fuel Pump/Fuel Pump Relay Problem (no crank) matrx10503 Grand AM 17 03-05-2009 12:32 AM
2000 Pontiac Montana Fuel Pump beachrog Montana/Montana SV6 6 09-07-2008 02:27 AM
'00 Bravada Fuel Pump Taylor44 Problem Diagnosis 6 03-26-2008 10:30 PM
2000 montana fuel pump relay goadster4 Montana/Montana SV6 1 12-16-2007 09:58 PM
Walbro Fuel Pump...good/bad? Worshp '88 - '91 Civic | CRX | Wagon | Shuttlee 6 09-29-2003 02:16 PM
