Go Back   Automotive Forums Car Chat > Chevrolet > Colorado
Old 01-03-2012, 04:04 PM
Pringle Bob Pringle Bob is offline
05 colorado
I have a 05 chevy colorado 4 door. The power locks do not work and also the driver side window does not work. All of the other windows work. The fuses seem to be ok. Any ideas??
Old 01-03-2012, 04:48 PM
fiserman fiserman is offline
Re: 05 colorado
Not sure this is just a shot in the dark but could it be the control cluster for windows and locks on the drivers side. Mabe the contacts are dirty or something else with it. One of these other guys ma be a expert on that. Good luck fiserman
The Following User Says Thank You to fiserman For This Useful Post:
Pringle Bob (01-04-2012)
Old 01-03-2012, 10:13 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 05 colorado
Fisherman may be right on. Key on, check the orange wire at the drivers side switch for power (12v), check the black wire for a good ground. The ground wire is in the same connector as the orange power wire. If power and ground are ok, the drivers switch assy needs replaced.
You are looking for the white connector. Orange is in position 1 and black is position 3.
The Following User Says Thank You to gmtech1 For This Useful Post:
Old 01-04-2012, 07:40 AM
Re: 05 colorado
whrer is the white connector located?
Old 01-04-2012, 07:43 AM
Re: 05 colorado
also where is the driver switch located
Old 01-04-2012, 08:11 AM
gmtech1's Avatar
Re: 05 colorado
The window switch assy on the L/F door.
Old 01-04-2012, 05:16 PM
Re: 05 colorado
Thanks again,We checked everything and it looks like I will need the whole assy. How much we looking at$$
Old 01-04-2012, 08:23 PM
gmtech1's Avatar
Re: 05 colorado
Rockauto.com has them for 122.00.
Pringle Bob (01-05-2012)
Old 03-14-2012, 06:40 AM
jsneden jsneden is offline
Re: 05 colorado
Just in case someone else looks at this... If the window controller on the left side is disconnected and then reconnected and fails to work, Unplug the mirror plug (forward), door lock (middle) and window power plugs (rear most) from the switch assy. Leave the key out and the door open until the dome light goes out. Reconnect the front plug, middle plug (identified by the bigger contacts in the plug) and then the rear plug IN THAT ORDER! Then test the door locks. If the door lock works, insert the key and try the windows. I am not sure why it works but we have several 2005 Colorado's and we had this problem and this seems to work.
Good luck!
Need a good Colorado Street Sceen. Nxtyoung Street Racing 15 07-17-2004 01:21 PM
Colorado peeps? desireems77 Western US 25 01-06-2003 11:12 AM
Colorado in the Spring? Maddog Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 11-05-2001 05:21 AM
Got my GoX invite from Colorado. Schludwiller Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 08-29-2001 02:13 PM
