Old 01-02-2012, 07:26 PM
heymanz heymanz is offline
low tire light on
hi i changed the wheels on a 2000 alero is there any way to put out the low tire light on the dash
Old 01-03-2012, 10:53 AM
skeeter123 skeeter123 is offline
Re: low tire light on
(make sure pressure in all tires is where you want it before doing this)
Turn Key-on, Engine-off. Pull off the driver's side fuse panel, find the red reset button. Push-and-release it once, note that oil change light starts blinking. Push-and-release it again, Low Tire light should start blinking. Push it in and hold it for 5-seconds, then release. I think you'll also hear the chimes sound. That should reset the tire-pressure sensing logic.
Hope this helps///
Old 01-03-2012, 01:25 PM
Tech II Tech II is offline
Make sure all tires are 30 psi.....Skeeter is correct....
