Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-02-2012, 04:10 PM
albert.iowa albert.iowa is offline
1500 dodge engine question
I drive 56 miles to work, once I reach work truck is running a bit rough. After work about 10 miles on the way home check in light comes on. By the time I get back home truck is running very rough. Shop cant find anything wrong. So far I have replaced fuel pump, plugs/wires, distributor cap and rotar. Keep reading P0171 code. This is on a 96' Ram 1500 2WD 130K miles 5.2L
Old 01-02-2012, 04:56 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1500 dodge engine question
P0171 Fuel System Lean.
A lean air/fuel mixture has been indicated by an
abnormally rich correction factor.
The O2 sensor is telling the computer that the exhaust is lean so the computer tells the injectors to richen up. Normally this communication keeps the air/fuel mixture in top shape but if the O2 sensor sends the computer misinformation, the process gets out of whack, as you well know now.
I'd look for an air leak. Broken or cracked vacuum line, loose intake or throttle body bolts.
All help gratefully accepted.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-02-2012, 07:53 PM
jamesslcx jamesslcx is offline
Hello albert.iowa, Chris gives good advice first check for vacuum leaks. Have you replaced the 02 sensor before? Check it and the wiring. Actually there are quite a few items that can cause this problem.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
2.7 to 3.2 Engine Swap Question ddennis002 Intrepid 1 12-01-2010 07:15 AM
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
2004 Dodge Ram 1500 Trailer Harness Question BertPod Ram Pickup | Ram SRT10 1 01-09-2010 08:56 AM
mg 1500 engine question. trickle66 General Discussion 0 06-04-2005 04:52 PM
