Go Back   Automotive Forums Car Chat > Car Buying Q&A
Car Buying Q&A Ask a question, get an answer; it's that simple. Visit AutomotiveHelper.com for useful car buying tools and research.
Old 12-30-2011, 03:56 PM
Doom10320 Doom10320 is offline
Worth buying? 1984 Camaro
So this guy i work with is saying that he would be willing to sell his 1984 camaro which he says its his "baby" but needs a car with more space for his kids cuz its a 2 seater. He wants to sell it for $1200 but im trying to get it to $1000, keep in mind this will be my first car. He also said that he keeps good care of it and the body is in pretty good shape sense i see it everyday at work.
These are the specs.
1984
305 5.0L Engine v8
120,000 miles
201,690 miles on body
Possie rearend
then 2 15" subs in the back
Pictures:
will not be taking those rims he has the older style that i will be taking if i buy
what do u guys think?
Old 12-30-2011, 05:21 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: Worth buying? 1984 Camaro
I would look up the car's value on vehix.com, edmunds.com and kbb.com to get a 3-way comparison of what the car's real worth is. None of the audio equipment really increases the value of the car... this car is almost as old as me - and I'm OLD. I'm guessing it's not worth $1000, but that will be largely dependent on your location. If you really want this car, get it checked out by a legit mechanic (unless you're highly mechanical and have the means to look it over in depth).
Regardless, let us know what you decide!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 12-31-2011, 12:59 AM
well im just looking for a reasonable car for $1000-1200 that wouldnt break down on me in like 2 weeks
Old 12-31-2011, 01:49 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
You are at the absolute bottom-end for a drivable car. Any $1000 car will not be great. Anticipate some problems and likely some repairs the car will need.
Frankly, at that budget , just look around for the best-condition car you can find, regardless of make or model. You might find that Grandma's old Tempo may be a better bet than this car. 200k miles is a lot for any car. You may have some nasty surprises, such as worn steering rack, worn ball joints, struts etc.
Give this car a close look. Check all sterring, suspension, brakes, tires etc for wear. Look closely for rust. If the car is reasonably rust free, and runs and drives well, $1000 is worth it. As noted above, get a mechanic to check it out. If it needs much work, don't buy it.
Generally these cars are pretty reliable and straightforward-enough that a skilled owner can do many repairs themselves. Again, rust is the big issue. The automatic transmissions sometimes fail if the car is driven hard (the ring gears like to break).
Some of the body and interior hardware is a bit fragile. The doors are frameless, so worn, sagging hinges and/or bad door seals make for annoying air leaks past the windows.
Old 05-10-2012, 02:55 AM
Jamesfranklin Jamesfranklin is offline
Banned
No a car like that can have many problems and you don't want to buy a car that you cant drive because of problems. If you want a camaro with that body style in that year or around that year then look on craigslist or bay for one that you can compare it to. If i were you i would take a look and look at certain spots in the car. Look under the driver and passenger floor mats in the wheel wells and in the trunk if there are any holes you don't want it. If it runs and you can have a mechanic look at it to make sure its not going to die in a couple days. I wouldn't buy it but if it runs and is what you want go for it.
1984 Camaro Z28 305 Overheating problem. Packczy Camaro Discussions 12 06-12-2014 08:09 PM
1984 camaro z28 cruise control kitsapchopper Camaro Discussions 3 02-16-2005 09:29 AM
1984 camaro v6!!!!!!!!!!! need a v8 brad_26 Camaro Discussions 13 09-15-2004 03:06 AM
1984 Camaro Z28 For Sale sdnicker Camaro Discussions 3 02-02-2004 10:29 PM
1984 Camaro, 5-speed manual (v4) Snowlock General Discussion 0 11-01-2002 03:02 AM
