Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 12-28-2011, 03:58 PM
dustyben dustyben is offline
Send a message via Yahoo to dustyben
L6 250 new carb set-up questions
I have a 1968 Chevy II/Nova w l6 250 engine. I have been getting horrible mpg ( 8-9) & found that the cam on the back of the carb had fallen off. I had bought the car barely running & know that the screws were set all over the place. I set the lower screw about one turn out from seated & adjusted the upper idle screw. The car ran better but doesn't stay, it always needs adjusting. Rather than rebuild the leaky & broken thing- does anyone know what the set up should be, once I buy & install a new Rochester monojet? I would rather some sort of quick way to install throttle body injection but...
Dusty
Old 12-29-2011, 01:02 PM
j cAT j cAT is offline
Re: L6 250 new carb set-up questions
I would start with using a vacuum guage and repair all vac leaks.
make sure the float is adjusted correctly after that , then adjust the mixture screw using the vacuum guage .
replace the fuel filter often .
new exhaust set-up crazi-85crx '71-'87 Civic | CRX 8 09-21-2005 01:15 PM
carb set up leaded to unleaded s3boy Golf 1 11-14-2003 08:19 AM
N/A set-up question.. grncivicdhr 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 12 11-10-2003 01:12 PM
Calmini has a new steering set up for the Xterra... cmxterra Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 8 06-14-2002 07:03 AM
ignition set up question! mellowboy '71-'87 Civic | CRX 17 01-02-2002 02:50 PM
