Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-28-2011, 01:58 PM
Hooyah Hooyah is offline
Camry head gasket Emergency!
I dropped the new cylinder head on this 94 camry. Torqued down all the bolts to spec and then I went under the car to get the bolts on the back of the head. HORRORS! a small bracket holding a sensor got wedged in with the head gasket. It's maybe a mm high and a mm deep in between the head and gasket. I can't seem to pull it out.
I installed a new head with new bolts and washers. If I loosen the head bolts in order again and retighten them should it be ok? These bolts are not tty so they can be reused. I just always get new ones when doing head gasket.
Attaching a pic. Blue circle shows where it is wedged in.
Old 12-28-2011, 04:08 PM
DeltaP DeltaP is offline
Re: Camry head gasket Emergency!
Is it on the head side of the gasket or the block side? If ya cant pull it out ... it aint good. Probably deeper than a mm. Gonna cost ya another gasket at least. Just curious as to which side of gasket as the head is aluminum and it'll probably leave a mark. But the gasket has been distorted from an uneven clamping force. If it were mine i'd pull the head and check. Then replace the gasket.
Old 01-10-2012, 11:01 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You'll definitely need a new gasket since the bracket has probably cut the one you have. You'll probably have to pull the head anyways to check that the bracket didn't make an indent into the head or the block surfaces. If so, you'll have to smooth them out with fine wet/dry sandpaper. If it is deep, you'll probably have to use a bit of JB Weld or Quicksteel putty to fill it and sand it flat. Put shop rags in the oil galley next to it to keep debris out when working on the block.
The head bolts are tightened an additional 90° after the second torque down. They are not reusable after you have done the 90° step.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
96 Altima : Trouble Starting After Head Gasket Replacement EliteDistance Altima 15 05-31-2010 03:56 AM
Head Gasket Leak or LIM Gasket? Bozly Monte Carlo 4 01-18-2009 05:44 PM
Intake gasket leak or head gasket vfour65 Impala | Impala SS 9 09-02-2008 07:37 PM
95 Camry Head Gasket leaks WHoDEy Camry/Camry Hybrid/Vista 7 08-11-2005 03:56 PM
85 Camry head gasket Blitzgray Camry/Camry Hybrid/Vista 0 03-01-2005 09:47 PM
