Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 12-24-2011, 04:07 AM
ajaxxx420 ajaxxx420 is offline
Cool olds 1996 delta 88 3800 II series wont start!
Ok so it has a new battery and it turns over and cranks just doesnt start no fuel. valve has lil too no pressure...so i replaced the fuel pump and filter but with the same problem. any thoughts would be very helpful.
Old 12-24-2011, 08:58 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: olds 1996 delta 88 3800 II series wont start!
Is the fuel pump running? Have you checked the fuses? Replaced the relay? Is there power at the fuel pump? A fuel pressure gauge would be helpful.
Old 12-24-2011, 10:31 AM
Tech II Tech II is offline
Does the car start if you spray carb cleaner into the intake?
If yes, then it's fuel delivery......you say there is no fuel pressure when depressing the schraeder?
Providing you hooked everything up correctly, next step is to disconnect harness at tank and attach a test light to the fuel pump circuit....should light for 2 seconds with key on.....be on constant during cranking.....
Old 12-24-2011, 06:23 PM
i did get it started it turns out it was a security system problem...it is in the ignition. thanks for the input. if it does this again i will have to bypass the vats and will probly be back on this thread again thanks for the help guys.
Old 06-27-2012, 01:04 PM
well im back but i didnt have to bypass the vats it was the ignition starter switch unside the steering colum...
95 Bonneville 3.8l vin.K wont start Tonedog Bonneville 41 01-07-2012 10:29 PM
3800 Series Stumper AdamWGregg LeSabre 13 04-18-2010 03:47 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 07:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 07:44 PM
Delta 88 Royale Wont Start (lost For Ideas) KEVEN1767 Eighty Eight 36 12-05-2005 10:01 AM
