Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 12-22-2011, 01:10 PM
comet240 comet240 is offline
04 3 sensors need to be replaced where are they
hi i helping a friend dont have a service book for this van
its a 04 2 wheel drive i thinking venture van
the code scanner said
Oil pressure switch
Crank Sensor Block
Crank Sensor Pully or something like that
where are they and is it hard to get remove etc and i thought engins only had one crank sensor?
Old 12-23-2011, 02:06 PM
lesterl's Avatar
lesterl lesterl is offline
Re: 04 3 sensors need to be replaced where are they
What were the P codes?
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 12-26-2011, 09:43 AM
oh i dont know off hand now
i only wrote down
that it was oil pressure switch and said the 2 Krank sensors is there more then one of each of these on these new engines ill have to rescan it then
Old 12-26-2011, 11:01 PM
lesterl's Avatar
Sensor in side of block between firewall and engine (mid block), one up top behind/ under power steering pump, and a third IIRC in the front down low behind harmonic balancer........ So what were the codes.......
Oil Level switch is in the bottom of the pan, IDK of an oil pressure switch, again, what are the codes......
Get the codes pulled and let us know, it may not be bad sensors......
Old 12-26-2011, 11:06 PM
lesterl's Avatar
Were the intake gaskets or any work recently done? IIRC the sensor wires on one are easy to nick/ cut when replacing the intake gaskets...
IF it actually runs the 7x sensor on the firewall side of the block is good (it connects to the Ignition Control Module and allows it to know when to fire.....
Where are they? enzo@af VehiCROSS 20 07-29-2008 01:54 PM
O2 Sensor and Fuel Filter Where Are They? mr.Hand Metro 7 05-07-2008 06:43 PM
Spark Plugs Where Are They I Need Serious Help Now.... Kidlex01 Grand AM 3 04-02-2005 05:43 AM
Where are they??? MaximusGTR Galant 7 01-08-2003 04:25 AM
Where are they??? Sanchi Sentra | 200SX (USDM FWD) 15 03-15-2002 09:25 AM
