Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-22-2011, 12:30 PM
majones majones is offline
94 Camry 4cyl--How to get drive shaft out of transaxle
Hi-
I have a 94 camry 4cyl auto and am following the factory service manual to remove the drivers side drive shaft from the trans axle--I want to replace the shaft seal which is leaking. I have it apart down to where I need to pry the shaft out of the transaxle but having trouble getting it out. I don't have the hub nut wrench the manual recommends am using or trying to use a pry bar without much luck. Is there fastener holding the shaft into the transaxle (i have the other end free of the wheel hub)? Thanks for any advice.
Old 12-22-2011, 05:28 PM
DeltaP DeltaP is offline
Re: 94 Camry 4cyl--How to get drive shaft out of transaxle
When you have it down to where you are the axle is only held in by a puny little snap ring on the end of the splined shaft. When you do get it out and look at it yer gonna laugh! You're workin on the shorter shaft,the drivers side. Some times they yank right out by hand and some can be a biotch. Try to support the shaft straight and get a good grip and position on that prybar. I've also learned to lift that car as far as you can,safely,supported on jackstands. That gives you more leverage from better positions. HTH
Be careful not to bugger up the seal riding surfaces on the shaft if yer reusing it.
The Following User Says Thank You to DeltaP For This Useful Post:
majones (12-27-2011)
Old 12-27-2011, 10:13 AM
I haven't managed to get the axle auto of the transaxle yet. Potentially dumb question, there is a flange with 6 bolts around where the shaft goes into the transaxle. The manual instructed to loosen these to finger tight and then pry out the axle...which I did (all but prying out the axle part...sigh.) My question, the flange is pulling away from the transaxle, does the shaft and this piece come out together or does the shaft pull through it? thanks.
Old 12-27-2011, 11:28 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The shaft and flange should come out as one piece. When I had to replace mine I don't recall loosening the six Allen bolts. The shaft portion that enters the transaxle differential is splined and at the end is a spring C-clip. Prying the drive shaft out will compress the clip and release the shaft. Pry slowly and firmly with a big pry bar and a good positioning. As noted, make sure the car is well supported. It can take alot of force to get that clip to release.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-21-2012, 08:41 AM
Daniel M. Dreifus Daniel M. Dreifus is offline
AF -Advisor
Originally Posted by majones View Post
Hi-
There's a secret. I had the exact same problem and an excellent local mobile mechanic had the answer.
First, you need a decent pry bar. The pry bar I'd been using came from Harbor Freight and was essentially junk. It would flex when you pried on it. Went to NAPA and spent around $30 on a really solid pry bar, plus I've since found it really useful elsewhere, like for tensioning belts.
Here's the secret. The circlip that rests in a groove in the axle inside the transaxle case obviously has an open end. You need to keep turning the axle until you're prying when that open end is facing up. So you pry with reasonable force, then turn the axle a bit and pry again. When you hit the right spot, it should pop right out.
The Following User Says Thank You to Daniel M. Dreifus For This Useful Post:
Brian R. (01-22-2012)
95 Camry 4cyl - No spark Bosco11 Camry/Camry Hybrid/Vista 18 09-12-2010 07:18 PM
86 caprice. 305 to 350. drive shaft lengths? m3gas3th Caprice 11 05-12-2009 10:40 PM
Can't get half shaft out of transaxle!!!!! JH32552 Camry/Camry Hybrid/Vista 6 08-29-2007 12:27 AM
99 gxe auto can't get half shaft into transaxle jas_stang Altima 2 04-26-2007 08:15 AM
93 Camry 4cyl left hand drive shaft removal phil-l-fixit Camry/Camry Hybrid/Vista 4 10-02-2006 01:00 PM
