Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 12-21-2011, 12:38 PM
scot399 scot399 is offline
2001 impala 3.4l
Thanks in advance. Getting a p0401 and a p0135. Have replaced the MAP sensor and the EGR valve with no improvement. Also cleaned the exhaust tube to the EGR valve and the EGR opening to the intake manifold.
Any ideas?
Old 12-21-2011, 03:59 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 impala 3.4l
The P0135 is a O2 sensor code. As far as the EGR code, if you are sure there is no restriction in the EGR system, check the wiring at the terminals for the MAP and the EGR for being broken in the insulation.
Old 12-29-2011, 04:51 PM
Interesting cure. I thought I had cleaned the passage from the EGR valve to the intake. To be sure I removed the butterfly valve body and MAF sensor so I could see into the intake.
The opening from the EGR tunnel into the intake was clogged like you wouldn't believe. Like coal. I couldn't tell before because the passageway took a sharp turn just before the intake tunnel and I couldn't reach through from outside. Cleaned the hard tarry stuff out and problem cured.
Thanks for your help.
Old 10-20-2012, 03:31 PM
Solddaboat Solddaboat is offline
This is exactly what happened to my 2001 3.4... tunnel was totally blocked with hard black stickey build up... got it cleaned out and check engine light is now off and I got it inspected....
01 Impala 3.4L Solitudeofmind Impala | Impala SS 2 05-15-2011 09:35 AM
1996 Monte Carlo Z34/ Cutlass Supreme 3.4L Idle Learn Procedure 96cutlass3.4 Monte Carlo 0 06-17-2010 10:43 PM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
2001 impala 3.4L v6 hennpala Impala | Impala SS 2 07-10-2006 04:19 PM
2002 Impala 3.4L Marsal420 Impala | Impala SS 0 03-04-2006 06:39 PM
