Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-20-2011, 03:02 PM
pmwibif pmwibif is offline
Crankshaft Pulley Fell Off. Ugh.
So over this van. The crankshaft pulley fell off, I didn't even know it could fall off. Just the outer part, it has a very thin rubber lining on the inside. It came off when I started the engine and I immediately shut it down. Wth do I do?! Maybe I'm not even looking for the right part, but I don't see any crankshaft pulleys on my local auto parts websites.
Old 12-20-2011, 04:35 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Crankshaft Pulley Fell Off. Ugh.
Rockauto.com has them. Look up harmonic balancer.
The Following User Says Thank You to gmtech1 For This Useful Post:
pmwibif (12-21-2011)
Old 12-20-2011, 05:50 PM
Jrs3800 Jrs3800 is offline
I am going to hazzard a guess and say its either a 3.1 or a 3400?
What year is the van?
Old 12-21-2011, 02:47 AM
500hpgtx's Avatar
500hpgtx 500hpgtx is offline
A few years ago, our 3.8L 95 van had a terrible vibration that ramped up sporadically from idle. I had not time to work on it, and Firestone said it was the water pump. I told them it was not the pump, as I replaced it a few months prior for leaking and age. They replaced the water pump with no success.
The harmonic balancer was found to be torn. Van had around 120K miles at the time....merry Christmas guys
Old 12-21-2011, 11:29 AM
Sorry, It's a '98 with the 3400.
Old 12-21-2011, 11:32 AM
It has a terrible vibration too, for about 15 seconds from a cold start, throwing a code that says misfire in the #1 cylinder. So trying the hit or miss tactic, I replaced the spark plugs, which I hope to never have to do again on a Trans Sport. This pulley fell off as soon as I started the engine back up after the spark plug job.
Old 12-21-2011, 02:04 PM
Tech II Tech II is offline
Like GMTech1 said, it's called the harmonic balancer......this had to have a bad vibration for some time......they don't just come apart right away...
Old 12-21-2011, 02:15 PM
Well the 15 or so seconds of "misfiring" at cold start ups has been happening for about a month now. And with the engine code pointing to cylinder 1, I was advised to change the plugs and/or injectors. Then the belt started slipping and tearing. So now knowing that pulley is a "balancer", the misfiring feeling makes more sense. Thanks!
But now what is involved in replacing that? I see a repair sleeve here, or do I have to replace the whole balancer?
Old 01-04-2012, 12:35 PM
rkvons's Avatar
rkvons rkvons is offline
You'll have to rent a crankshaft pulley puller and pull it off and replace it with a new one. Without an impact wrench, the bolt that holds it on can be difficult to remove. You can put a wrench on it and lay it strategically across a frame member and bump the starter with the key for a split-second to get it off.
The Following User Says Thank You to rkvons For This Useful Post:
pmwibif (01-26-2012)
Old 01-26-2012, 01:17 PM
LMP's Avatar
LMP LMP is offline
Yes--the whole balancer.
A few pictures from a 3.8. Probably quite similar qith the 3.4
www.avigex.ca/xport/ckpphoto.jpg
www.avigex.ca/xport/cksphoto.jpg
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
The Following User Says Thank You to LMP For This Useful Post:
Old 01-26-2012, 01:24 PM
Thanks for the help everyone. I did rent a puller and did the job, but upon completion, the engine ran worse than before, as if the balancer coming off had messed up the timing. That was the last straw, and the next day I sold the van on Craigslist as a mechanic's special. This van had given me more problems than any other vehicle I'd ever owned, and I only had it for just over a year.
92 deville 4.9 Power Steering Pulley sheered / fell off and destroyed belt! 92Deville Deville 1 06-03-2009 06:51 PM
problem getting off crankshaft pulley on 98 camry cbohnd Camry/Camry Hybrid/Vista 4 06-09-2006 08:55 PM
help 96 3.2 rodeo crankshaft pulley bolt will not come off! realglassman Rodeo | Passport | MU 2 11-27-2005 09:46 AM
Crankshaft pulley trying to come off whydoubt Grand Prix 0 03-26-2005 10:00 PM
