trunk pop?
I have a 95 caprice and recently my trunk pop will not work inside the glove box or on my remote. I push the button and nothing happens. Anyone had this problem before?
Re: trunk pop?
Check your fuses.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: trunk pop?
i cant find a fuse in the book that has anything to do with a rear lid release or trunk release. I do notice a small black box on the back of the trunk lock that must release the lock when the button is pushed. Is it possible this needs replacing?
Re: trunk pop?
That should be the solenoid. To prevent wasting money on parts that might not need to be replaced, test the voltage present on this line. Have a helper press the trunk pop button while you check the voltage on this line. If you get 0 volts, the solenoid won't be the problem.
There is a fuse for every electric system in the car. Check the fuse block. I have a Haynes book for my own car and it didn't detail the fact there are three fuses that control the ECM. It showed one, which made tracing a problem with my ECM, several years back, pretty interesting. The problem was a blown fuse (due to a failed, shorted sensor) that was not in the book.
| The Following User Says Thank You to silicon212 For This Useful Post: | ||
94HeavyChevy (01-04-2012)
Re: trunk pop?
ok thanks for the help i will check all fuses. hopefully one of them is blown.
Re: trunk pop?
you could also jump 12 volts to the truck actuator connection to see if it works. measure resistance of the truck actuator coil. etc... |
Re: trunk pop?
Not sure if this is the case with you......some systems have a slider switch near the solenoid, to enable/disable the system.....otherwise, disconnect harness to solenoid, and attach a test light....then operate the system with either switch...if it lights, it's the solenoid...if it doesn't, it's the circuit....
Re: trunk pop?
thanks for the help guys. solenoid was shot.
Re: trunk pop?
thanks for the repair info. where did you buy the replacement new/used ? |
Re: trunk pop?
i got it at a junk yard for 3 bucks.
Re: trunk pop?
how was the junk yard stock on these 94-96 caprices ?
Re: trunk pop?
there was only 1 there. so not stocked very well at all.
