Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 12-18-2011, 11:19 PM
scott17818 scott17818 is offline
Exclamation broken lower control arm
My mother was having issues with her 1998 subaru legacy outback wagon, said she was driving home from the hospital and heard a loud pop, and then nothing else happened. so I went to go check out the car thinking it might be a bad CV joint, and would have to replace one of the front CV shafts. I started up the car, and simply turned the wheels.. come to find a dead spot in the steering, and simply gave it some more juice.. I heard a loud bang, and the car shimmey a bit.. odd.. so I cranked the wheel lock to lock a few times.. it never happened again.. so I took the car out for a little test drive to see if I could re-produce the sound.. I went to turn into a neighbors driveway, and heard a loud bang accompanied by a grinding noise, and shuddering throughout the whole vehicle.. I get out and look the the drivers side tire.. looks fine... the wheel is perfectly straigh and in place as it should be.. the passenger side however is turned into the fender, and back about 4 inches from it's usual spot.. i look down at the lower conrtol arm that is completely rusted through.. so the only part holding the lower control arm in is the rear attactchment, and the upper control arm..
is there a subaru recall on this? I've tried searching, but some up with unrelated info on other models/years. thanks
Frt Lower Control Arm scotschult Crown Victoria 12 12-17-2010 09:04 AM
1994 Park Ave - Broken Rear Control Arm Bushing Bolts murphyjr Park Avenue 2 11-26-2005 02:11 PM
lower control arm offset bushing?? walt0023 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 12-26-2002 11:30 AM
SRR rear lower control arms & sway bar? Tofuboy Engineering/ Technical 1 04-12-2002 11:04 PM
Type R Suspension - All 4 dampers and rear lower control arms Provocateur Tires and Wheels 1 03-14-2002 04:40 PM
Tags
arm , control , corrosion , lower , recall
