Old 12-18-2011, 10:54 PM
sandman065 sandman065 is offline
Windshield washer and high beam switch issue - 2004 Grand Caravan SE
I recently noticed that my front washer fluid was not working. I thought it might be the washer pump, after checking the fuse box and all seeming fine. But, the result of checking the fuse box has me rethinking the issue. Tonight, while driving, I noticed that my high beams switched on a few times when I tested the washer fluid switch, and the "mist" wiper/washer fluid combination operation was switched on when I tried the high beam switch. I would appreciate all knowledgeable and experienced diagnostic and repair suggestions, thanks.
Old 12-20-2011, 01:56 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Windshield washer and high beam switch issue - 2004 Grand Caravan SE
Judging by the underwhelming response, this looks like a rare problem. I can say this is only the second time I've read about it in years of cruising forums. The first one is a current thread on another forum. Here's the thread so you can keep an eye on it for an answer. Just my response there so far: http://www.dodgetalk.com/forums/showthread.php?t=347503
The players are the multifunction switch, the Front Control Module (FCM), the Body Control Module (BCM) and the PCI data bus. If I had to bet I'd pick the switch module. That's only a guess. Could try pulling the IOD fuse for 2-3 minutes. This will reset the BCM and data bus.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
sandman065 (12-20-2011)
Driver side window operation and washers are out Moonzuk Sierra 0 06-16-2009 10:25 AM
HIgh beam switch, steering column tahuya_eagle Sierra 0 12-28-2006 12:39 PM
1999 Dodge Ram 1500 High beam switching dodgerian Ram Pickup | Ram SRT10 0 09-11-2005 02:04 PM
replacing turn signal/high beam switch ricmann MPV 0 05-31-2005 08:24 PM
