Go Back   Automotive Forums Car Chat > Fabrication & Tools > General Tools
General Tools Discussions about tools - there are thousands of various tools you can use to work on your car. Do you have the right one for the job?
Old 12-18-2011, 01:38 PM
ashokri ashokri is offline
ODB scan tool
Hi All
I have a used car dealer, with over 80 cars in stock (American, Jerman, and Japanese). I'm looking to buy a scan tool to check engine light, ABS and Air bag.
Any advise will be appreciated.
Ash
Old 03-14-2013, 01:21 AM
AndrewTeal's Avatar
AndrewTeal AndrewTeal is offline
Re: ODB scan tool
get one with as many reprogramming, relearn, reflash capabilities as you can, you need to be able to read monitors and command actuators and tell the ecu to test different components...i try to use the manufacturers oem software/scantool... tech2 for gm, drb3 for crystler, techstream for toyota, etc..but thats not always possible
Knowledge is Power.
Old 03-14-2013, 11:06 AM
AndrewTeal's Avatar
Re: ODB scan tool
Originally Posted by Christopher583 View Post
If the module were dead that would explain the lack of communication, but would not explain the function of the ABS light.
abs light being on means the module is disabled or malfunctioning
Knowledge is Power.
obd2 plug scan tool will not connect sdime9484 Problem Diagnosis 1 01-01-2010 12:49 PM
ODB-I Scan Tool? MashBill Suburban 2 03-14-2005 11:24 PM
OBD Scan Tool and Oxygen Sensor Location Jagmeister Maintenance 2 08-30-2001 09:26 AM
