Old 12-17-2011, 11:43 AM
jamesmetairie jamesmetairie is offline
1998 tranny question=
1998 ,3.1 has about 165,000 miles. Never changed the transmission fluid.
Occasionally when I parked at a stop light when I get the green to go I give it gas and hear the engine rev but the car does not move. Usually I slip it down into regular "drive" and then all is ok. then put it back into overdrive later.
Is this one of the symptoms of a transmsssion that,s about to totally fail?
Old 12-17-2011, 02:39 PM
maxwedge maxwedge is offline
A990 racer
Re: 1998 tranny question=
Is it full, is the fluid dark and burnt?
Old 12-20-2011, 11:55 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Sounds kinda like a valve body and/or solenoid failure coming.
If I got that kinda miles out of a trans without servicing it, I'd feel blessed.
If it's mine, I'm gonna do pan drop/filter replacement/one quart of Trans-X and see what happens. It'll either fix it or kill it off for good.
Anyone tries to tell you to get a full fluid exchange/flush tell them no thanks. Quickest way I've discovered to destroy a marginal transmission. Partial fluid change only, just what you get out of the pan. Reuse the OE gasket, way better than that POS they give you with the filter kit.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-22-2011, 01:57 PM
thanks guys.
it,ll be the fingers crossed method.
makes for exciting road trips .
Old 12-22-2011, 02:21 PM
maxwedge
yes. the level is good. i had this car since it had 44,000 miles and never put one drop of a/t fliud in it. it never leaks .
the a/t fliud is slightly discolored and it smells used.
Old 12-22-2011, 07:03 PM
A990 racer
Sounds like it may try to start in 3rd gear default or it is just slipping, get ready for some internal issues.
1998 VW Passat Tranny Jerks! Problem with Tranny? or Engine? serjay '97+ 0 06-10-2006 09:56 PM
1998 tranny kugstrand18 Blazer 1 10-28-2005 08:45 AM
1998 Tranny problem hixie00 Jimmy 0 07-11-2005 11:53 AM
