Old 12-14-2011, 07:20 PM
sheilao sheilao is offline
Transmission?
I have a 2007 Dodge Grand Caravan with a 41TE transmission, I have been having problems with it not recognizing Park and Neutral. I took it to the shop (after my dad tried fixing it) and they replaced the Neutral Safety Switch. $360 later, when I picked up the van today they said they had the same problem. I need to leave in the morning so I was kind of stuck into leaving with the same problem I started out with. Anyone have any ideas what else this could be?
Old 12-15-2011, 10:23 AM
jpb53 jpb53 is offline
Re: Transmission?
Does the van crank and start okay, or is it the display on the cluster that is the problem? It does not have a neutral safety switch it has a transmission range sensor. If it cranks and starts in only park and neutral then more than likely that is not the issue. You could have a communication prblem between the PCM and cluster, or a cluster issue. The wiring diagram will show you what I am talking about.
Saving $ on transmission fluid killermrob83 Crown Victoria 2 12-17-2011 10:35 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
