Old 12-13-2011, 08:19 PM
dagan06 dagan06 is offline
02 with random misfire
Was backing out of the driveway and heard a pop and the engine light came on. car still ran and was giving a random misfire code p0300. Changed the plugs, wires and coils to no avail. Was going to take it to a shop but now it won't start at all. Someone said it may have jumped time I had timing chain changed less then a year ago.
Old 12-13-2011, 09:23 PM
Tech II Tech II is offline
Re: 02 with random misfire
Which engine?
Check spark output on all cylinders with a spark tester?
Check compression?
Will it start if you spray carb cleaner into intake?
Old 12-14-2011, 12:42 AM
the engine is 2.2 ohv. coil spark output is fine on all cylinders but compression when it ran was low on cylinders 1 & 4. but now that it won't start there is no compression on any cylinder. I can try the carb cleaner but I don't think it will help due to the lack of compression
Old 12-14-2011, 12:18 PM
I agree....with no compression, it's not going to start....
I think this is an interference engine, if it did jump time(tensioner went bad, chain broke), the valves are probably bent....sorry, but it looks like a major problem....
Old 12-14-2011, 05:52 PM
It is noninterference the chain broke on us before and I had a shop replace it. I was told that the aftermarket tensioners do not hold up. I am wondering it the new tensioner broke
1998 grand prix GTP 3.8L V6 supercharged, random misfire gtpmaddi Grand Prix 2 04-19-2011 08:16 PM
98 Tahoe Random Misfiring jbrown_tahoe Tahoe 7 02-16-2010 11:27 PM
02 Dakota Multiple/ Random Misfire, Cylinders 2,4,5,6 osuyaqui Dakota 3 04-09-2009 08:49 AM
