Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 12-13-2011, 01:55 PM
Cbpcop's Avatar
Cbpcop Cbpcop is offline
Cool O2 sensor replacement question
Stats: 98 4runner, 4 cyl, automatic, 2wd, 150,000 miles.
Question: what kind of mileage impact can the O2 sensor(s)have on the vehicle if one or both are bad. Neither has ever been changed. Nucklehead 1 (toyota service guy) says save your $ - just not necessary to change 'em. Nucklehead 2 (auto parts store guy) says Change 'em - could cause as much as 2 mpg loss or even more.
Also, what other kind of performance losses can they cause if they have gone bad?
Thanks in advance for the input.
Old 12-13-2011, 02:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: O2 sensor replacement question
I don't think they have a substantial decrease in mileage if the front one is bad. Even though you would think so, I didn't notice a difference (although I didn't leave it in for long after I had the trouble code). The rear sensor will not affect performance since it is only a catalytic convertor efficiency indicator.
I wouldn't change them unless you get a DTC (Check Engine Light) indicating one or the other are bad. You may loose some power if the front one is bad. Note that if you receive a trouble code indicating poor catalyst efficiency, it is most likely a bad rear sensor, not the cat convertor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-21-2011, 09:30 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Yeah, either one being bad can cause a noticeable mpg loss, the EFI isn't running in it's most efficient mode.
But if any are bad it should also cause a error code and trip the engine light.
Big question, what made you take it to the shop to begin with?
If just lower mpg, could be other things.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Question: 2003 with W8-sensor problem? loocha '97+ 5 09-01-2009 09:00 PM
96 Civic HX o2 Sensor Replacement.... shvd98z24 '96-'00 Civic 3 03-30-2009 08:49 PM
Replacing manual lever position sensor aka: transmission range sensor digglett21 Thunderbird 1 07-17-2008 06:18 PM
Oxygen sensor replacement-question please... sprat Cavalier 10 03-07-2006 08:02 AM
