Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-12-2011, 07:26 PM
famlycar famlycar is offline
2 Big Questions for 96 Corolla
First question is how long does the timing belt last in the 96 corolla --- is it 60000 or 100,000? or longer? anyone out there have a belt to last longer?
Second Q is my exhaust system smells bad but there doesn't appear to be any holes or rust anywhere in the exhaust line or muffler. So far with over 200,000 miles on the car the exhaust system has never been replaced. Could the problem lie in the oxygen sensor? I heard that there are 2 of these sensors. one sensor in front and one under the passenger side floorboard... is this correct?? Or could the problem be the emissions system like the charcoal cannister?
A carload of thanks!
Old 12-12-2011, 11:57 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 2 Big Questions for 96 Corolla
60k under severe conditions - 90k normally. Severe conditions are stop/go driving with extreme weather conditions.
For the smell, what does it smell like? Sulfur? Sweet? Burnt oil? any smoke?
Yes, there are two sensors. One in the exhaust manifold and one just after the catalytic convertor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 12-13-2011, 01:14 AM
thanks Brian.
I've got 75000 miles so it's about time for the timing belt
The smell is just like the smell of normal exhaust I guess, no smoke but a vapor can be seen from the tailpipe which dissipates quickly; and oil is good--- no leaking or burning.
I changed the sensor in front about 50,000 miles ago but not the one behind the converter; so if the sensor's not operating, will it will cause the bad exhaust? are both sensors the same type? thanks
Old 12-13-2011, 03:04 PM
Brian R.'s Avatar
Resident Chemist
No, the rear convertor has no effect on mixture. It is only an indicator of catalyst efficiency. No, the sensors are normally different. Sometimes the gas you use can have a higher sulfur content and cause a bad smell. May be your catalyst burning off some contamination. I wouldn't worry about it. It can only cost you money with little or no potential permanent solution.
Another car stereo question Speculant Car Audio 11 08-18-2010 06:37 PM
Big plans for my car - lots of questions P_Mac GTRA / GTWS / GTS 9 06-01-2010 11:09 AM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
Big Question for all you engine buffs wfot71 Prelude 3 08-02-2004 07:53 PM
big stereo for sale or trade for wheels/kit/hood for 91 civic slammedcivicsi '71-'87 Civic | CRX 4 01-21-2002 03:30 AM
