Go Back   Automotive Forums Car Chat > Saturn > General Discussion
Old 12-12-2011, 12:32 PM
Jakaii Jakaii is offline
Crankshaft Journals bigger than they're supposed to be?
So I need some help. I just recently bought a 1997 Saturn SL2 with a 1.9L 4-cylinder DOHC engine. The engine was knocking when we bought it, which is why we got it so cheap. (we figured it was a connecting rod bearing, which it was)
So we pulled the engine, and I took off the oilpan, oil baffle, and then the connecting rod caps. Sure enough, bearing 1 (closest to the timing chain) was spun like a monkey. So my dad and I decided to just replace all 4, since the other 3 were slightly worn and it's obviously a good idea while you have the engine apart.
TO THE POINT: we thought it would be relatively easy to replace the bearings right? NOPE. when measuring the journals of the crankshaft with a calipers, they measured from 1.845 inches (that was the spun one) to 1.862. That's a good tenth of an inch BIGGER around than my Haynes Repair Manual says they should be! So, is it a modified crankshaft? and what kind of bearings do I get?
Crankshaft Journal sizes leonbentz Metro 8 04-28-2010 12:41 AM
My Love is Bigger Than a Honda - Chicagoist Automotive News Automotive News Desk 0 09-06-2006 05:10 PM
NA Z32 Throttle-bodies Bigger than TT's? 1viadrft 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 36 10-30-2004 03:37 PM
Be all you can be? No-no-no...be MORE than you can be! carrrnuttt Politics, Investments & Current Affairs 5 07-24-2004 09:20 PM
