Old 12-12-2011, 09:53 AM
killermrob83 killermrob83 is offline
transmission flush procedure
Have '02 3.0L SES Taurus with AX4N transmission/transaxle with 128K miles. What is the best way to flush the system? I will be replacing the filter, also. Any suggestions on what to use to install a drain fitting in the pan? Is the pan gasket a reuseable gasket? Thank you for your time and consideration.
Old 12-12-2011, 07:19 PM
Willyum Willyum is offline
Re: transmission flush procedure
Is imprinted right on the OEM gasket that it is reusable. If you put a drain in the pan you still should take it off to get the pan and magnet clean.
I have drained, replaced the gasket, cleaned the pan and magnet on my '02 every 30K miles and at 110K it still shifts like it did when it was new. Never have "flushed" it.
Old 12-15-2011, 08:29 AM
tempfixit tempfixit is offline
If you want to flush the system remove the return transmiission line from the radiator and attach a long clear hose to the line, so you can watch for change in color of fluid and also put in a gallon jug to determine approx how much you have removed. Of course do this after you have removed pan and replaced new filter and added approx 4 quarts of fluid.
Then start engine and let it pump out some of the old fluid (best if someone is in the car while you watch fluid) shut off engine add same amount of fluid into tranny, repeat procedure until satisfied old fluid has been replaced. (This does get the fluid out of the convertor also)
Old 12-22-2011, 08:38 AM
plymouthsrock plymouthsrock is offline
I agree with tempfixit, except that I replace the pan and filter last, after the last "dump". Empty pan easier to handle.
heatercore flush procedure yardman Century 2 03-16-2009 09:51 AM
Radiator flush procedure 2002 v-6 Weedo Silverado 2 11-07-2006 01:27 PM
sketchy trans flush procedure bombergp Caravan | Voyager 0 05-09-2006 10:12 PM
coolant flush procedure oinka ZX2 1 07-26-2005 04:20 PM
