Old 12-11-2011, 12:40 AM
stapled stapled is offline
2005 Cavalier Spraying Gas
At intake... and possibly return?
Been smelling gas in the car while driving for a while now. Kind of intermittent, sometimes not at all and sometime really strong. Sometimes gas smell comes from engine after car has been turned off. Sometimes when it idles and sometimes when the car is in motion. Had a couple crackhead mechanics look at it and $10 later they swore it was fixed. It wasn't, but I didn't have time to deal with it and the car hasn't had any problems running.
Now I'm on break from school so I have some time to put into working on the car. So yesterday I had the hood up and found that gas is spraying from where the fuel line goes into the fuel rail, and I couldn't tell for sure but it looked like it might also be coming out where the return line connects.
I have done in-line repairs before, but I don't know much about fuel systems so I'm not sure whether I just need to fix where the lines connect or if there's some part inside that may need to be replaced.
Old 12-13-2011, 06:10 PM
viggy58 viggy58 is offline
Re: 2005 Cavalier Spraying Gas
i believe they make a "nut kit" that will fix that. check with your local parts store. you'll want to bleed the pressure off before hand.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
The Following User Says Thank You to viggy58 For This Useful Post:
stapled (12-29-2011)
Old 12-13-2011, 09:16 PM
Tech II Tech II is offline
Sounds like o-rings....
The Following User Says Thank You to Tech II For This Useful Post:
Old 12-29-2011, 08:01 PM
I checked at the parts store for a "nut kit", but the guy didn't have a clue what that was and I wasn't sure either, so I asked for o-rings instead. He gave me upper and lower fuel injector o-ring sets. I wasn't sure if that was what I was supposed to get but that's all he offered so I took them anyway. After replacing both sets and cleaning up the injectors the car is running much better and I can no longer see the leak, but there is still a gas smell coming from the engine while it is running and for a while after it is turned off, so I'm pretty sure it is still leaking.
Do I still need a nut kit? And if so, what exactly is that? Or if I just need o-rings for the lines does anyone know what size they need to be?
Old 01-05-2012, 12:37 PM
sorry, i was thinking of my blazer when i mentioned the nut kit. i believe the cav/sunfire just has the o-rings.
something you can do that is free, hit up the parts dept at your local dealership and ask them to print out the exploded view/diagram of the fuel lines. it will show every part on there.
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Better gas mileage Stapletonb08 Cavalier 3 03-03-2011 01:02 PM
88 astro 4.3 fuel injectors spraying gas BIG TIME RAYDIOED M Bodies 3 10-28-2007 05:08 PM
2005 Cavalier tx77 Cavalier 8 10-11-2004 02:29 PM
Non Tech, Will there be a 2005 Cavalier Frank G Cavalier 2 08-26-2004 02:47 PM
HELP 84 Cavalier spraying out coolant PhReAzE Cavalier 1 03-05-2004 12:45 PM
