I am looking to adjust my toe in and camber.
I came across this interesting note in another thread: "Sloppy steering is probably the alignment. I aligned mine to the (factory) specs, and it was still not very good. [factory= -ve .33 degrees camber (negative = top inward, bottom of tire out) -ve .12 degrees toe in (positive = toe-in closer at front than rear) I then adjusted the camber to -1.5 and the toe to .4, night and day difference, ' and the tires wear completely normal. I would actually say the handling is "good" with those numbers, I would give the factory alignment "below average". It handles better than most cars now. Caster was whatever it was at before (around 4?), it doesn't affect handling so I didn't waste time adjusting it. " And I also found this handy chart/quick instruction guide:
Refer to the chart below to convert to minutes or degrees of toe. There are 60 minutes to one degree. A good rule of thumb is 1/16 inch toe in per wheel front and 1/8 inch toe in per wheel rear for a car doing autocrosses/time trials. NOTE: This chart is based on a toe gauge that is 24 inches wide and will NOT be accurate for other WIDTHs. Toe measurement 1/16 inch or 0.0625 inch = Toe angle 8.95251minutes Toe measurement 1/8 inch or 0.125 inch = Toe angle 17.9051 minutes Toe measurement 3/16 inch or 0.1875 inch = Toe angle 26.8578 minutes Toe measurement � inch or 0.25 inch = Toe angle 35.8106 minutes Toe measurement 5/16 inch or 0.3125 inch = Toe angle 44.7638 minutes Toe measurement 3/8 inch or 0.375 inch = Toe angle 53.7172 minutes Toe measurement 7/16 inch or 0.4375 inch = Toe angle 1.04452 degrees Toe measurement � inch or 0.5 inch = Toe angle 1.19375 degrees Toe measurement 9/16 inch or 0.5625 inch = Toe angle 1.343 degrees Toe measurement 5/8 inch or 0.625 inch = Toe angle 1.49225 degrees Toe measurement 11/16 inch or 0.6875 inch = Toe angle 1.64152 degrees Toe measurement � inch or 0.75 inch = Toe angle 1.79079 degrees Toe measurement 13/16 inch or 0.8125 inch = Toe angle 1.94008 degrees Toe measurement 7/8 inch or 0.875 inch = Toe angle 2.08938 degrees Toe measurement 15/16 inch or 0.9375 inch = Toe angle 2.23869 degrees Toe measurement 1 inch = Toe angle 2.38802 degrees 3. Camber measurement, perform after measurement of toe in.
NOTE: This chart is based on 15inch diameter wheels, the most common on 914’s it seems and will NOT be accurate for other diameters. CAMBER MEASUREMENT BASED ON 15 INCH WHEELS Camber measurement 1 - 32nds or 0.03125 inches = Camber angle 7.16201 minutes Camber measurement 2 - 32nds or 0.0625 inches = Camber angle 14.324 minutes Camber measurement 3 - 32nds or 0.09375 inches = Camber angle 21.4861 minutes Camber measurement 4 - 32nds or 0.125 inches = Camber angle 28.6483 minutes Camber measurement 5 - 32nds or 0.15625 inches = Camber angle 35.8106 minutes Camber measurement 6 - 32nds or 0.1875 inches = Camber angle 42.9731 minutes Camber measurement 7 - 32nds or 0.21875 inches = Camber angle 50.1358 minutes Camber measurement 8 - 32nds or 0.25 inches = Camber angle 57.2987 minutes Camber measurement 9 - 32nds or 0.28125 inches = Camber angle 1.07436 degrees Camber measurement 10 - 32nds or 0.3125 inches = Camber angle 1.19375 degrees Camber measurement 11 - 32nds or 0.34375 inches = Camber angle 1.31315 degrees Camber measurement 12 - 32nds or 0.375 inches = Camber angle 1.43255 degrees Camber measurement 13 - 32nds or 0.40625 inches = Camber angle 1.55196 degrees Camber measurement 14 - 32nds or 0.4375 inches = Camber angle 1.67137 degrees Camber measurement 15 - 32nds or 0.46875 inches = Camber angle 1.79079 degrees Camber measurement 16 - 32nds or 0.5 inches = Camber angle 1.91022 degrees Camber measurement 17 - 32nds or 0.53125 inches = Camber angle 2.02966 degrees Camber measurement 18 - 32nds or 0.5625 inches = Camber angle 2.1491 degrees Camber measurement 19 - 32nds or 0.59375 inches = Camber angle 2.26856 degrees Camber measurement 20 - 32nds or 0.625 inches = Camber angle 2.38802 degrees Camber measurement 21 - 32nds or 0.65625 inches = Camber angle 2.5075 degrees Camber measurement 22 - 32nds or 0.6875 inches = Camber angle 2.62699 degrees Camber measurement 23 - 32nds or 0.71875 inches = Camber angle 2.74649 degrees Camber measurement 24 - 32nds or 0.75 inches = Camber angle 2.866 degrees Camber measurement 25 - 32nds or 0.78125 inches = Camber angle 2.98552 degrees Camber measurement 26 - 32nds or 0.8125 inches = Camber angle 3.10505 degrees Camber measurement 27 - 32nds or 0.84375 inches = Camber angle 3.2246 degrees Camber measurement 28 - 32nds or 0.875 inches = Camber angle 3.34417 degrees Camber measurement 29 - 32nds or 0.90625 inches = Camber angle 3.46374 degrees Camber measurement 30 - 32nds or 0.9375 inches = Camber angle 3.58334 degrees Camber measurement 31 - 32nds or 0.96875 inches = Camber angle 3.70294 degrees Camber measurement 32 - 32nds or 1 inches = Camber angle 3.82257 degrees From the pictures on that page, it appears the toe-in measurements (in inches) are done at front and rear of tire, i.e., the difference divided by 2. (1) Is this the same way to measure the Camber? (2) What do you think of the recommendations regarding going a bit outside factory spec to get better handling and tire wear? Has anyone else experimented with camber/toe-in on a Cavalier, with or without stabilizer-bar, and also in snow (understeer/oversteer) vs. dry road conditions? What do you recommend? Last edited by GuyWithCavalier; 12-09-2011 at 11:21 AM. |
