Old 12-07-2011, 01:32 PM
jamesmetairie jamesmetairie is offline
mixing engine oil question=-
1998 Lumina with about 165k. Ran 10w30 for many years.
Now I have a 5 quart bottle of castrol 5w30 and I can,t get a refund.
Is it safe to use it in the Lumina and switch back to 10w30 in the future ?
Old 12-07-2011, 04:20 PM
maxwedge maxwedge is offline
A990 racer
Re: mixing engine oil question=-
The 3.1 calls for 5/30 the 3.8 calls for 10/30 so which is it?
Old 12-07-2011, 04:57 PM
It,s the 3.1 . The oil cap on the valve cover does say use 5w30. But I,ve been using 10w30 for along time and heard somewhere that it ain,t good to switch back and forth.
Old 12-07-2011, 08:21 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I switch back and forth every spring and fall. 5W/30 for our cold winters and 10W 30 for the hot summers, with no problems.
Most owners manuals give some kind of temperature range and oil viscosity recommendations. For example, my '97 Cadillac says 10W 30 on the oil filler cap, but the owners manual suggests 5W 30 of the ambient air temp is consistently below 60 deg F. Above this temp, 10W 30 is recommended.
Old 08-12-2012, 11:13 AM
jimbob0077 jimbob0077 is offline
You have good reason to be concerned. The Oldsmobile Cutlass 2.5 liter lifters were sensitive to the viscosity. However I wouldn’t worry at all about putting that 5/30 weight oil in the car during the winter months. Look at your owners manual, it should have some kind of chart regarding what viscosity oil to add at what ambient temps.
Old 08-12-2012, 06:41 PM
j cAT j cAT is offline
he is supposed to use 5-30wt oil. the 10-30wt would be for temps above 40degf. if he wanted to . the spec is 5-30wt or 10-30wt. gm manual says to use 5-30wt.
don't know about that small olds block.
I know my 400cu olds used 10-30wt no problem.
Bitron Engine & Fuel stabilizer dlbitron Cars in General 0 07-27-2009 10:57 AM
flat engine oil questions Reed Engineering/ Technical 7 01-22-2007 06:32 PM
Engine Oil Question... uprightness Introductions 2 09-29-2005 09:29 PM
