Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 12-06-2011, 05:42 PM
ttrout ttrout is offline
2002 yukon xl fuel pump
After banging on the gas tank every now and then for the last two years to free up the fuel pump it finally gave out. Cost me $865.00 at the dealership, 2hr labor, 1 hr diag. plus fuel pump. This seems high to me, did I get jobbed?
Old 12-06-2011, 08:27 PM
maxwedge maxwedge is offline
A990 racer
Re: 2002 yukon xl fuel pump
Break down the parts and labor, 1hr seems high for a diagnosis which you did for them. A fuel pressure test takes 5 minutes, what else could they diagnose other than that and your description of what occurs.
Old 12-06-2011, 08:56 PM
old_master's Avatar
Advisor/Moderator
Amazon has brand new AC Delco and Delphi pumps, (same thing the dealer installs). You can usually can find them for right around $200, sometimes even less. A couple of hours, (maybe three if you're a rookie) using regular tools and you're done. Or $865.00 you make the call
You have to know how it works,
to figure out why it doesn't.
Old 12-08-2011, 10:55 AM
Thanks guys, knew I could probably do it myself, just a time issue.
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 11:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-05-2009 12:39 AM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 10:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 09:04 AM
2002 Yukon Fuel pump Failure Hagg Yukon 6 02-01-2005 06:48 PM
