Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 12-04-2011, 04:18 PM
GaJim GaJim is offline
Drained Radiator, now leaking
Changed the coolant on daughter's 2001 VW New Beetle recently and now the radiator drain plug (aka a pitcock?) is leaking very slowly. Almost as if the thing is not tightly connected. Does anybody know how to remove the drain plug and repair it?
TIA, Jim
Old 02-08-2012, 09:27 AM
mark_gober mark_gober is offline
Re: Drained Radiator, now leaking
I realize this may be too late, but I'll offer my advice anyway...for future readers.
I've been working on my niece's beetle lately and the radiator petcock threw me for a loop. Whereas most radiator petcocks simply unscrew to open, the VW's is different. You rotate it 90 degrees to unlock it and then just pull it out. To close, you push it back in and rotate it 90 degrees clockwise. It's wierd, but that's how you do it.
Old 02-19-2012, 03:29 PM
Yea, I finally figured it out. I wound up having to gently pry it out with a flat blade screwdriver. Replaced the O-ring and no more leaks.
2001 Durango 4.7L radiator drain plug mcknt Durango 0 09-26-2009 01:52 AM
Radiator is leaking - now what? nmikmik SC/SL/SW 10 08-19-2009 06:02 AM
Had radiator replaced now leaking transmission fluid venturenot Venture 3 06-07-2009 10:28 PM
Tags
leak , radiator
