Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 12-02-2011, 07:27 PM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
2005 Aveo Timing Belt Question
Who has a link to timing belt replacement instructions?
Old 12-03-2011, 05:08 AM
autojoe autojoe is offline
Re: 2005 Aveo Timing Belt Question
www.autozone.com
Old 12-03-2011, 05:30 AM
toni1595 toni1595 is offline
There is one right here on this site, http://aveodiy.blogspot.com/
Did you try a search? It is a little sketchy, but you get the idea.
Toni
Old 12-03-2011, 05:03 PM
leonbentz's Avatar
Toni
Yea, sketchy is right. No indication on the crank sprocket location. Oh well, I got it done and found the valves are all toast.
Old 12-04-2011, 07:41 AM
I did mine a couple of years ago, there should be a notch in the timing belt cover and a mark in the sprocket IIRC.
Did you go over the 60,000 mile limit? If so, you're on borrowed time after that I think.
I would also recommend changing the water pump and associated pulleys while you're right there, might save some headaches later on. Next time I do one of these, I'm going to get a kit from Ebay, comes with the whole package. I'll try to post a link: http://www.ebay.com/sch/i.html?_from...All-Categories
Of course if the belt has broken with motor running as you have alluded to, then you'll be looking for a reconditioned head or getting yours repaired. Either way, quite costly.
Toni
Chevy Aveo timing belt TSB davidy Aveo 0 07-23-2009 10:58 AM
'09 aveo timing belt or chain ? aveo5? Aveo 3 09-18-2008 10:25 PM
95 ex timing belt question ne0h74 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 10-16-2003 08:35 PM
ZC timing belt question 94tegRS Engineering/ Technical 2 09-01-2003 01:15 AM
Timing belt question. . . help! ocd Engineering/ Technical 1 09-09-2002 08:01 PM
