Old 11-30-2011, 07:21 PM
tacosoldier tacosoldier is offline
Two Trouble Codes
On my 1999 Oldsmobile Intrigue 3.8, my scanner picked up 2 codes:
1. P1651, I replaced the relay twice, then replaced the fuse box. It still pops up. Where do I look?
2. P0336, I took it a mechanic, he replaced the sensor, then replaced a seal to stop an oil leak on to sensor, then on the third trip he did a relearn. The damn code still shows up. Don't know if he did the relearn incorrectly or just got ahold of a defective sensor from the parts store. About the relearn, several mechanics have told me that its not necessary. One said that if it was 2000 or newer, its imperative but not on that year. I'm confused now and all I can say is, HELP!!!
Old 11-30-2011, 09:54 PM
Tech II Tech II is offline
Re: Two Trouble Codes
Do you have power to the relay?
Have you checked the harness between the sensor and the ICM? Also check the connectors at the sensor and ICM.....
Does he have a scan tool capable of performing the relearn?
Old 12-04-2011, 09:16 PM
Sorry about delayed reply, work in retail. What can I use to test the relay issue?
The mechanic said that they wiring was fine. I assume it was capable of the relearn. I have a Actron Autoscanner plus and had hopes it could, I went thru its menus but couldn't find anything about Crankshaft variation relearn.
87 2WD Pick Up - Two Decades of Starting Problems MSW78 Older Pickups 5 11-21-2009 09:45 AM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
I have three codes two codes that I need help with PLEASE!!!!!!!!!!!!!!!! [email protected] Accord/TSX/Accord Hybrid 2 05-11-2007 04:54 AM
Trouble Code Troubles seethru B-Series/Bravo/Bounty/Drifter 0 06-18-2006 05:16 PM
Trouble Code Trouble projectgsr Prelude 0 04-28-2005 05:57 PM
