Old 11-30-2011, 04:48 PM
PolarStorm PolarStorm is offline
1997 Blazer 4wd issue, Please help
Hello,
Im a new user and have read the forums but so many pages not sure if this question has been answered already.
I have a 97 blazer and am having 4wd issues. anmely getting into 4wd hi. Have not used it in a while and now with the snow here i need it.
when i press the 4 hi buttonnothing happens. when i put in neutral, and press, both the 4hi and 4lo lights flash, but then stops and just stays in2wd.
if in neutral, i pres the 4 lo button, it does engage without problems, but i cant very well drive in 4 lo all the time. please help if possible, as i cant afford to take this to a mechanic to trouble shoot it. thankyou forayreply or suggestions you may have.
Old 12-01-2011, 08:49 PM
old_master's Avatar
Advisor/Moderator
Re: 1997 Blazer 4wd issue, Please help
Welcome to the forum!
Under the battery tray there is a vacuum actuator that operates a clutch in the front axle housing. With the engine at idle, select 4WD HI. Vacuum should now be applied to the actuator and you should see the actuator pull the cable toward the actuator about 3/4". Post your results.
You have to know how it works,
to figure out why it doesn't.
2000 Blazer 4X4 issues please help snow on the way pensfan74 Problem Diagnosis 1 12-09-2009 08:49 AM
1989 4wd Blazer, solid axle... please help me! TheAutoDoctor Problem Diagnosis 4 02-28-2009 08:04 AM
1999 Jimmy 4WD drive issues - Please help jr_greatwhite Problem Diagnosis 9 08-25-2008 06:37 PM
1998 S10 Blazer with issues!!! Please help!!! Fire237 Problem Diagnosis 1 04-03-2007 05:36 AM
1997 Blazer, odd acceleration. PLEASE HELP! Wet Sand 12 Blazer 3 01-04-2005 06:49 PM
