Old 11-30-2011, 12:47 AM
Grand346 Grand346 is offline
Blower motor or Resistor?
I slashed in small floods in the rain just before hurricane Irene, and my blower motor went out and won't run on any settings on my 2000 grand pix gt, how would I know if it's the blower motor or the blower motor resistor?
Old 11-30-2011, 09:36 AM
Tech II Tech II is offline
Re: Blower motor or Resistor?
That much water? Could be one or both.....
First thing to do, is turn blower on, and then tap the motor housing with a hammer......if it starts, bad motor....
If that doesn't work, disconnect harness from the blower motor.....attach a test light to the harness......turn key to on....turn blower on through all speeds....if test light progressively gets brighter, need a motor.....
If it doesn't light at all, disconnect the harness to the resistor block and check for power there....if you have power, then bad resistor block....if no power, check fuse...if fuse ok, bad control head.....
Old 11-30-2011, 08:26 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Welcome to the forum!
Before anything else, it would be good to know if you have either automatic or manual AC. There is a difference on the location of the resistor for both cars. If you have automatic AC the resistor is likely to be OK since it is mounted far from the blower motor.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-30-2011, 08:31 PM
brcidd's Avatar
brcidd brcidd is offline
Any "W" cars with bad blower motors- I always look for the rubber water deflector to be "off" its mount - just above air inlet to blower motor. Water can run in and short out the blower resistor big time....remove passenger side cowl at base of windshield and examine if your water deflector is still mounted. The glue dries out and deflector falls off on about half of the ones I examine. I clean and re-glue to fix..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-06-2012, 01:55 PM
anc33 anc33 is offline
I have 97 grand prix gtp,had problems with blower motor making a ratiling noise n was poping the 30 amp mini fuse,i replaced the blower motor and the resistor,,and still doesn't work ,i checkd every fuse in the car and under the hood everything was good and still blower doesn't work ,.I already got over 1000 dollars invested in the car brand new suspencion ,.,.please if someone could help me n tell me what else should I look for to make this blower motor work before I pour gasoline on this car and burn it ,.,.,.
Old 03-06-2012, 04:04 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Welcome to AF!!
Remove the blower motor and make sure that the motor is working by connecting it to at 12 volt source. Then test the connection to see if there is power coming from the resistor to the motor. It is possible that one or the other may be bad. If that doesn't work you may have to replace the ignition switch that sends power to the resistor. This usually doesn't fail but if no power is going to the resistor then the fan will not work.
Old 03-06-2012, 04:29 PM
I did replace blower motor and brandnew resistor ,.,.what u are sayn Is probly I bought defective parts?
Old 03-06-2012, 09:02 PM
Did you try what I wrote in post #2?
Old 03-06-2012, 09:11 PM
Im gona test tomorrow to see if its da ignition switch ,,,
Old 03-07-2012, 02:30 PM
I removed blower motor tested n it was good, power is good coming from ignition switch to resistor ,so what I did was replace the plug goin to resistor n put everything together n now blower does work but only on # 5 speed ,.,.wat else culd b wrong
Old 03-08-2012, 07:58 AM
Pontiac Guy
The resistor you purchased is either bad or had a bad connection or both. Usually when the resistor is not working correctly the fan will only work on 5.
Old 03-08-2012, 09:04 AM
Ok so i called the auto parts store where I bought da resistor and they are gona exchange it ,,,grrrrrr lol ,now I goto pull everything out again to pull out da resistor,,,.. thanks gtp DAD
Old 03-08-2012, 12:20 PM
I replaced the resistor again an still works only on #5 speed and wat I noticed to is when I put it on speed #5 and move the temperture knob from red to blue that's when the blower turns on,,,whats causing that
blower motor resistor, blower or both? hammer2 Grand Prix 14 03-11-2012 07:16 PM
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
Blower Motor Resistor schoss1200 3 Series 0 07-02-2003 11:43 AM
Visual HOW TO:fix your blower motor resistor SupraNemesis Maintenance 0 03-06-2003 02:46 AM
Help me locate blower motor resistor. novice Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 02-06-2002 03:58 PM
