Old 11-29-2011, 03:47 PM
Tom Logan Tom Logan is offline
Question Looking for paint code alternative
Hey guys
Just got my first kit in years, Fujimi ID-47 Nissan Skyline GT-R V-Spec R32 1/24.
As soon as I opened it, I noticed a slight "cut" that goes across the roof of the car, probably a mold fault?
Anyway, I would like to make the car as good as possible, which basically means the paint job needs to be as good as possible. Im thinking about using car paint, but Im not sure how much of Nissans LP2 midnight purple should I buy?
Are there any quality, non-agressive paints that are similar to factory colors? I noticed many paint jobs have big flakes (metallic effect) which makes them look unrealistic. Any solution for this?
Thanks for your time guys! Cheers
Old 11-29-2011, 06:38 PM
corvettekid_7684 corvettekid_7684 is offline
Re: Looking for paint code alternative
I've been using Duplicolor paint with their primer sealer with good results. All I can say about metallics is try one & see how you like it. Some aren't bad, but larger flakes will look out of scale. Not a car, but my 1/48 Airwolf model looked good with its metallic paint. Hope that helps
Old 11-29-2011, 06:46 PM
BVC500 BVC500 is offline
How about paint designed for car models, such as Zero Paints (available at hiroboy.com) or Scalefinishes (scalefinishes.com)?
Old 11-30-2011, 12:55 AM
Any ideas how to achieve a finish like this?
http://www.automotiveforums.com/vbul...d.php?t=911108
I didn't see any particular explanations in the thread, and from what I've seen, it's the best damn paint job on a model car I've ever seen.
Old 11-30-2011, 08:01 AM
good painting techniques, a clean environment, the use of Zero's 2k clear properly thinned, and polishing, if necessary.
Old 11-30-2011, 12:14 PM
stevenoble's Avatar
Originally Posted by Tom Logan View Post
Hey guys
You can try passing the paint through a paint strainer or an old pair of nylon stockings/tights. This will help to remove some of the flake from the paint and create a more 'realistic' scale effect...
Steve Noble
Looking for liverys Agony Graphic Manipulation 0 11-03-2010 03:24 PM
Looking for ODB Codes for my Bird squibb94tbird Thunderbird 4 03-22-2005 11:33 PM
Looking for paint codes/sources av8 General Discussion 0 12-25-2004 09:03 AM
Looking for 94 amp alternator MagicRat General Discussion 1 06-01-2004 02:09 AM
looking for paint gun and have ?'s burgundygondola Cars in General 0 12-22-2003 03:28 PM
