Old 11-29-2011, 03:02 PM
lucasi_1 lucasi_1 is offline
brake issues
first of all hello to all!!
okay i have a 2001 taurus wagon with brake issues now. i changed the pads and the rotors in the rear and now everytime i give it brake it feels like when you stopping in ice or snow where the abs is trying not to make the car slide? i've taken these things off 4 times even replaced the new rotors with another new pair cause i thought maybe one was warped. i've bleed the brakes and it still does it. didn't do this before i changed them BUT the rear brakes were metal to metal when i changed them. any ideas? i think the calipers are fine no shaking at all its just everytime you stop the abs or something is making a noise and you can feel the pedal pulsate
Old 11-29-2011, 04:12 PM
tempfixit tempfixit is offline
Re: brake issues
Have you cleaned the abs sensor and ring on the rear axles?? I take it this did not happen before installing new rotors and pads. Double check to make sure the wiring to the sensors did not break.
Old 11-29-2011, 05:16 PM
Re: brake issues
well i don't see any abs sensors on the back of this car nor any wiring. car isn't throwing any codes either. i've changed hundreds of brakes and never seen this happen before....mind boggling
Old 11-29-2011, 06:55 PM
Re: brake issues
well i talked to my buddy and he told me with the engine off to pull the abs fuse out which i did and it stop the problem and it stops great. so would that be the abs speed sensor? and will it hurt to leave the fuse out til i can get back to working on it?
Old 11-29-2011, 08:21 PM
Re: brake issues
No. 8 in the lower pic is the abs sensor and No 3 shows the sensor ring. WIth the fuse removed the brakes work just older vehicles without abs brake system. ABS codes cannot be retrieved with a regular engine code reader, you need a ABS code reader, which would direct you to the problem wheel.
Brake issues GodsGirl73 Caravan | Voyager 4 05-05-2010 04:45 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
03 Malibu Brake Issue frame1520 Malibu 1 03-01-2009 09:25 AM
brake system issue or engine start system issue? lmei007 Engineering/ Technical 2 09-22-2007 04:28 PM
help, speratic brake issues and throttle-off-idle issues. 94tegRS Camry/Camry Hybrid/Vista 3 11-08-2006 02:56 AM
