Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-01-2003, 01:03 PM
godofrock godofrock is offline
Abs In Op Light
This light is lit on my dash,,whats the problem?
When I hit the brakes they go to the floor.
Old 06-01-2003, 01:47 PM
SupergirlRS'97 SupergirlRS'97 is offline
Send a message via AIM to SupergirlRS'97
Anti-lock brakes
ABS is your Anti-lock brake system what you need to do is turn off your car off then turn it back on so it can reset and the sign should come up for a few seconds but if it comes up while your driving it's probabaly not working so you need to go get that checked because that prevents you from skidding. But nothing should be wrong with your regular brakes but if another sign comes up dealing with your regular brakes then you defintely need to go get it checked you probably just need some brake fluid but go get it checked anyway.:flash:
Supergirl
Old 06-03-2003, 02:50 PM
Cy@tirerack Cy@tirerack is offline
To big and important of a problem to diagnose remotely, get it check out locally. You can find local mechanics by going to:
http://www.tirerack.com/installer/index.jsp
and entering your zip code.
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
'95 Town car ABS light on and hesitation olopezm Town Car 5 12-02-2010 06:30 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
95 silverado abs light is on and smells like brakes joseriverasg Silverado 2 12-21-2009 10:15 AM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
